Why transverse wave cannot propagate in a gas or in liquid?
The discussion centers on the propagation of transverse waves in gases and liquids, exploring the reasons why such waves cannot propagate in these mediums compared to solids. Participants delve into the mechanics of wave propagation, the nature of atomic interactions in different states of matter, and the theoretical existence of weak transverse waves in fluids.
  • Some participants propose that transverse waves cannot propagate in gases and liquids due to the lack of a restoring force that would return particles to an equilibrium position after being disturbed.
  • Others argue that while transverse waves can theoretically exist in fluids, they dissipate quickly due to weak coupling mechanisms and high levels of dissipation.
  • A participant mentions that particles in gases do not have a fixed equilibrium location, which allows for longitudinal waves to propagate instead.
  • One participant raises a question about surface waves, noting that they can occur when disturbances are introduced at the surface of a liquid, such as when a stone is thrown into a pond.
  • Another participant clarifies that surface waves are distinct from transverse waves in the bulk of the fluid and that they also fade out with depth.
  • Several participants provide detailed explanations of atomic interactions in solids versus fluids, emphasizing the role of equilibrium locations in solids that facilitate transverse wave propagation.
Participants generally agree on the fundamental reasons why transverse waves do not propagate in gases and liquids, but there is disagreement regarding the existence and characteristics of weak transverse waves in fluids. The discussion remains unresolved on the extent and implications of these waves.
Some claims about the nature of wave propagation in fluids depend on specific definitions of equilibrium and may involve assumptions about atomic behavior that are not fully explored in the discussion.
sphyics
please do explain in detail.
How can a transverse wave propagate in a solid?
I think it is because particles in gas doesn't tend to memorize its height or its distance to some wall. In gas you should observe memory of (mean) relative distance between particles. Thus you may have longitudinal wave.
best regards
DaTario
In fact they can but they fade out very quickly. They are called viscosity waves.
Any wave dissipates with distance but the viscosity waves are weak (the coupling mechanism is weak) and the dissipation is too strong.
sphyics said:
wat does tis mean by ?
A transverse wave propagates in a solid because each atom of the solid has an "equilibrium location" where the forces on it from all its neighboring atoms balance. If one atom gets pulled out of its equilibrium location by a disturbance, it will tend to be pulled back to that location. However, when it's out of its equilibrium location it pulls its neighbors out of their equilibrium locations too, and so on down the line; the end result is that a transverse wave disturbance propagates through the material.
In fluids (liquids and gases), atoms have no "equilibrium location"; they can move freely past each other. So if one atom gets moved by a disturbance, there's no restoring force to pull it back to its equilibrium location, because there is no equilibrium location. Instead, as DaTario said, each atom is driven by the forces of neighboring atoms to maintain a given average distance between itself and its neighbors, but nothing else; so if one atom is disturbed, it will move to restore its average distance to its neighbors (and they will move in turn in response to the first one moving), but the atom won't be in the same place it was before when it's done equilibrating again. This allows longitudinal waves to propagate in fluids, but not transverse waves.
Are we discounting surface waves here eg the waves I produce when I throw a stone in a pond?
Yes, we do. They are surface waves. They fade out with depth quickly.
As I said, the transversal waves in liquid are possible in theory and practice but they are extremely dissipating, not propagating far away.
thats indeed a great explanation :)
  • · Replies 47 ·
10K
42K
  • · Replies 37 ·
