| Thread Closed |
Changing Limits of Integration affects variable substitution? |
Share Thread | Thread Tools |
| Sep23-09, 10:48 AM | #1 |
see attached 2. Relevant equations 3. The attempt at a solution |
| Sep23-09, 09:12 PM | #2 |
Recognitions:
not exactly sure what the question is...
couple of points though, it is usually easier to use a different dummy variable when you use a subtitution say you have [tex] \int_b^a dt f(t) [/tex] and want to change to u(t) = t/2, then t=2u dt = 2.du u(a) = a/2 u(b) = b/2 so the integral becomes [tex] \int_{b/2}^{a/2} 2.du f(2u) [/tex] see how this compares with your case... |
| Sep26-09, 12:28 AM | #3 |
thanks
| Thread Closed |
| Thread Tools | |
Similar Threads for: Changing Limits of Integration affects variable substitution?
| MATLAB - changing variable name with each iteration? | Math & Science Software | 16 | ||
| variable substitution question(diff) | Calculus & Beyond Homework | 1 | ||
| variable substitution problem | Calculus & Beyond Homework | 3 | ||
| [SOLVED] Changing limits of integration | Calculus & Beyond Homework | 4 | ||
| changing variable in a sumation | Calculus & Beyond Homework | 3 | ||
