Phase equilibrium - beyond critical point
The discussion revolves around the concept of phase equilibrium, particularly in relation to the critical point on a phase diagram and the inclusion of plasma as a state of matter. Participants explore whether plasma can be represented in phase diagrams and the implications of phase transitions in this context.
  • One participant questions whether plasma can be included in a phase diagram and how such a diagram should be constructed.
  • Another participant argues that plasma is an ionized gas and suggests that phase transitions may not apply to plasma as it is not reached through a thermodynamic process.
  • A participant seeks clarification on the term "thermodynamic state," indicating a lack of understanding of how energy application leads to different states of matter.
  • There is a discussion on the limitations of classical thermodynamics in addressing the formation of plasma, with some suggesting that quantum thermodynamics may be relevant.
  • One participant proposes that fusion could also be considered a phase transition, indicating a potential overlap between classical and quantum perspectives.
Participants express differing views on the applicability of phase transitions to plasma and the definitions surrounding thermodynamic states. There is no consensus on how plasma should be represented in phase diagrams or the implications of including it.
Participants note that classical thermodynamics may not adequately address the formation of plasma, suggesting that definitions used in phase diagrams may be insufficient for this state of matter.
KLscilevothma
phase equilibrium -- beyond critical point
In a phase diagram, at critical point, liquid phase is indistinguishable from vapour, and beyond which, only vapour can be found. Matter has four states, liquid, solid, gas and plasma. Can we include plasma state in a phase diagram? If yes, how should the phase diagram be drawn? Also, I'm not very clear of what plasma state is, could someone give me a URL/explanation on that please.
Biology news on Phys.org
A plasma is just an ionized gas. I don't think phase transitions apply here since this is not a thermodynamic state, ie. we don't arrive at this state through a thermodynamic process...less the fact that we need a gas. Ionization can only be explained through QM.
How's the studying coming along?
An elememtary question, what is a thermodynamic state? I know if we apply lots of energy to matter, say sodium, it will change from solid state to liquid state, then to vapour state, and then turn into plasma, but I don't understand the term "thermodynamic state".
The last exam paper that requires me to study beforehand will be finished in 5 hours.
I know if we apply lots of energy to matter, say sodium, it will change from solid state to liquid state, then to vapour state, and then turn into plasma..
Hmmmm. True. I guess this gets to be risky business since it all come down to QM eventually. I guess what I meant was a state that can be described by the principles of thermodynamics - statistical calculations and such. I think the problem is that Classical Thermodynamics cannot address the formation of plasma. But you are correct that it is just another state dependent on the energy in the system. By this, I think that we could argue that fusion is a phase transition also. So, perhaps you touch on Quantum Thermodynamics with this question? I also think your point is valid. These do seem like other phase transitions. This could also be a simple matter of definition; the ones that we use fail to address your suggestion.
  • · Replies 18 ·
  • · Replies 109 ·
10K
  • · Replies 49 ·
