US Government's Biofuel Cap: Effects of Removing it?
  • Thread starter Thread starter fugg
    Limits
The discussion revolves around the US government's cap on biofuel usage, specifically the implications of removing the 10% limit. Participants explore the reasons for the cap, potential effects on engine performance, and compatibility issues with existing vehicles, focusing on both technical and political aspects.
  • Some participants question the rationale behind the 10% cap on biofuels and its potential removal, particularly in the context of engine hardware compatibility.
  • Concerns are raised about emissions and damage to exhaust components, with some suggesting that biofuels may burn less cleanly due to less regulation.
  • There is a discussion about the specific types of damage that biofuels can cause, such as clogging fuel filters and damaging catalytic converters, particularly in engines not designed for biofuels.
  • Some participants note that not all vehicles are compatible with all biofuels, leading to confusion among consumers regarding fuel compatibility.
  • Political influences, particularly from fossil fuel refiners, are mentioned as a factor in maintaining the biofuel cap.
  • Investment by major oil companies in biofuels is acknowledged, suggesting a complex relationship between traditional fossil fuels and biofuel development.
Participants express a range of views on the implications of removing the biofuel cap, with no consensus on the primary concerns or the technical challenges involved. The discussion remains unresolved regarding the overall impact of biofuel usage on engine performance and emissions.
Participants highlight limitations in understanding the compatibility of various biofuels with existing engine designs, as well as the potential for increased emissions and mechanical issues. The discussion reflects a variety of assumptions about the technical capabilities of modern engines and the regulatory environment surrounding biofuels.
fugg
The US government is encouraging and limiting biofuel growth at the same time. My question is, why set the current cap of 10% on biofuels? Why is that cap there, and what would be the effects of removing it, assuming that the engine hardware is bioresistant material (i.e. no brass/copper)? Are engine deposits the only concern? The lower energy density? Thanks in advance.
I would guess that emissions and/or damage to exhaust components would be the biggest concern. I think biofuels tend to burn less cleanly due to less regulation, but I'm not sure about that.
Hello. Biofuels have higher NOx emissions but generally lower carbon emissions to my knowledge so that wouldn't seem to be it. What damage exactly are you referring to?
Noone's familiar enough with biofuels to give a response?
From what I understand, if you run biodiesel or vegetable oil in a diesel engine, it can result in damage the catalytic converter due to more exhaust particulates being burned. In addition, fuel filters clog up faster, and fuel lines can "gel" with biodeisel in cold environments.
In engines that were not designed to run ethanol, the ethanol can eat through o-rings and seals that were designed for gasoline.
I think the point is that not all cars on the road are 100% compatible with all the biofuels out there, and there are a lot of people that don't fully understand the fuels or if their car would be compatible with it or not.
That assumption is the main technical reason; incompatibility. There's also some political pressure from the fossil fuel refiners which most governments won't have the appetite to address in one fell swoop.
Sounds like the confusion caused by the conversion to unleaded 20 odd years ago.
from what I have heard, the new diesel engines have a particulate filter. to clean it a "shot" of raw fuel is allowed to go out the exhaust valve to burn it clean, and bio goos up the filter.
I haven't taken a new one apart so don't know for sure
but, I have to wonder if it has to do with big oil wanting to control it
they can't be happy about the "bio-moonshine"
dr
Right but 'big oil' itself' has begun significant investment in biofuels on the scale of hundreds of millions in indiviual projects, as well as some of the big manufacturers like Rolls Royce.
The filter does seem a major hurdle given the replacement of seals/rings with appropriate material. Thanks for the response.
  • · Replies 19 ·
  • · Replies 19 ·
11K
  • · Replies 30 ·
