Statics Problem, Simple 2d rectangle with forces acting on it.
Thus, the line of action should be 300 mm to the right of D, and α = 77.63°.In summary, the equivalent force system for the given force and couple on a rectangular plate can be found by computing the sum of the forces in each direction. For part (a), with a given angle of 40°, the magnitude of the equivalent force is -48N and the line of action is at .256 m to the right of point D. For part (b), the line of action is 300 mm to the right of D and the angle is 77.63°.
LP20
A rectangular plate is acted upon by the force and couple shown. This system is to be replaced with a single equivalent force.
a) for a(alpha)=40 degrees, specify the magnitude and the line of action of the equivalent force.
b)Specify the value of a(alpha) if the line of action of the equivalent force is to intersect line CD 300mm to the right of D.
http://img188.imageshack.us/img188/3503/0926091619.th.jpg
Ok I've found the equivalent force-couple system at C which is -48N j, and +6.997 N.m. From there I'm lost, I don't know what to do. I've tried to use the cross product(CBxF) to find Moment at C then add up the moment... Am I going in the right direction?
Hint 1: What should be the value of the vertical force component for the equivalent force system? Hint 2: What should be the value of the horizontal force component for the equivalent force system? Hint 3: Now where will you place this equivalent force?
But, this is exactly what I don't get. Do I add force components from the force and the couple force together? Wouldn't the couple forces just cancel out, so you'd be left with 48 n?
Any other hints would help.
Yes, that's correct; -48 N. You got the vertical component of the equivalent force system. Keep going. See hints 2 and 3.
ok, so vertial force would be -48 N and horizontal would be 0 N. Alrighty, Thus the line of action would be on BC. Ok so what about part b). If line of action was 300mm to the right of point d? Wouldn't alpha be the same as it is now, just because it's part of a couple force and it produces no resultant force?? Is this just one big trick question?
I really do appreciate your help!
LP20: The line of action for part (a) is not BC. Try again. Hint 4: The equivalent force system must cause the same moment on the plate as the original force system. See hint 3. For part (b), alpha will not be the same.
WEll, Tomorrow this assignment is due, but no worries. I would still LOVE to figure this one out, its seems so simple yet its killing me on the inside. So The Magnitude of the equivalent force is -48N. And I thought the line of action is where the force follows the direction its pointing (which would be line BC?). *update* So I found the moment of couple M=fd (did each x and y component separately)... it is 2.313 Nm i + 4.596Nm j. Right? I set it equal to the rectangle with 300mm length (part b) Then I substituted my given length and moments I found into the equation M=fd, Than found out my alpha must be 32.15 degrees... Is this correct?? the answer just hit my like a ton of bricks... I hope I'm right!
For part (b), after you get your answer of alpha = 32.15 deg, now compute the moment on the plate using the original force system with your alpha. Next, compute the moment on the plate using the equivalent force system. I think you will see the original and equivalent moments do not match, which tells you your answer for alpha is incorrect.
Whenever you get an answer, you can then recalculate using that answer, to check the answer.
Alright nvn, I think I know how to do it, I already turned in my assignment today. We actually had a test on moments too. It went very smoothly. But I'll probably be back asking more questions in the future.
Thanks!
I know that this topic hasn't been addressed in a while, but I was also looking for the answer, and thought I would share with anyone else who needs help.
Part A
We must first find the sum of the forces in each direction, as LP20 noted.
The couple force of 15N has x-components that can be calculated using the α given (40°).
ΣFx: -15cos(40°) + 15cos(40°) = 0
Using the angle given again, we can calculate the y-components of the couple forces, in addition to the 48N force applied at B:
ΣFy: -15sin(40°) + 15sin(40°) - 48 = -48N --> 48N downward force
With the given angle of (40°):
15cos(40°)*(.4) + 15sin(40°)*(.24) - 48(.4) = -48*d --> eqt. 1
Thus, the 48N downward force is applied at .256 m to the right of point D.
Part B
We can use eqt. 1 above to solve for the new angle desired:
15cos(α)*(.4) + 15sin(α)*(.24) - 48(.4) = -48*(.3)
To solve this equation, we can use trig identities and the quadratic formula, as we get:
6cos(α) = 4.8 - 3.6sin(α)
Square both sides, use trig identities (cos2x = 1 - sin2x), combine like terms, and apply quadratic formula to find α = 77.63°
1. What is statics and how does it relate to this problem?
Statics is the branch of mechanics that deals with objects at rest or in a state of constant motion. In this problem, we are looking at a 2D rectangle with forces acting on it that are in equilibrium, meaning the object is not moving or rotating.
2. How do I approach solving this problem?
The first step is to draw a free-body diagram, which shows all the forces acting on the object. Then, apply Newton's First Law, which states that the sum of all forces acting on an object is equal to zero in a state of static equilibrium. From there, you can solve for any unknown forces or angles using basic trigonometry.
3. What are the different types of forces that can act on an object in statics?
There are two main types of forces: internal forces and external forces. Internal forces are forces within the object, such as tension or compression. External forces are forces acting on the object from the outside, such as gravity, friction, or applied forces. In this problem, we are dealing with external forces.
4. Can you explain the concept of moments in statics?
Moments, also known as torques, are a measure of the tendency of a force to cause rotation around an axis. In this problem, we can calculate the moment of each force by multiplying the magnitude of the force by the perpendicular distance from the force to the axis of rotation. The sum of all moments acting on an object must also be equal to zero in static equilibrium.
5. Are there any real-life applications of statics?
Yes, statics is used in many engineering and physics applications, such as designing structures, analyzing forces in bridges and buildings, and understanding the stability of objects. It is also important in fields such as architecture, aerospace, and biomechanics.
