Solving Poisson's Equation in 1D: A Shortcut Using Variable Substitution
  • Thread starter Thread starter th5418
    1d
The discussion focuses on solving Poisson's equation in one dimension using variable substitution. The equation presented is \(\frac{\partial^{2}}{\partial x^{2}} V = - \frac{I}{A\epsilon_o} \sqrt{\frac{m}{2e}} \frac{1}{\sqrt{V}}\), where all variables except for \(V\) are constants. The solution involves replacing partial derivatives with ordinary derivatives and defining a new variable \(W \equiv \frac{dV}{dx}\), leading to a first-order separable ordinary differential equation (ODE) for \(W\). This method is highlighted as a common and effective technique for tackling similar problems.
  • Understanding of Poisson's equation and its applications in physics.
  • Familiarity with ordinary differential equations (ODEs), particularly first-order separable ODEs.
  • Knowledge of variable substitution techniques in calculus.
  • Basic proficiency in mathematical notation and manipulation.
  • Study the derivation and applications of Poisson's equation in electrostatics.
  • Learn more about solving first-order separable ordinary differential equations.
  • Explore variable substitution methods in differential equations.
  • Review examples of second-order differential equations and their general solutions.
Students and professionals in mathematics and physics, particularly those dealing with differential equations and electrostatics, will benefit from this discussion.
th5418
Alright, well this is more of a math problem I guess... but here it is.
[tex]\frac{\partial^{2}}{\partial x{2}} V = - \frac{I}{A\epsilon_o} \sqrt{\frac{m}{2e}} \frac{1}{\sqrt{V}}[/tex]
Everything besides the [tex]V[/tex] is constant.
Trying to solve for the potential
What's the general solution for these types of second order differentials?
First, if it is a 1D problem, the partial derivatives can be replaced by ordinary derivatives!
Second, try defining a new variable: [itex]W\equiv \frac{dV}{dx}[/itex] and then take note of the fact that
[tex]\frac{d^2 V}{dx^2}=\frac{dW}{dx}=\frac{dV}{dx}\frac{dW}{dV}=W\frac{dW}{dV}=\frac{1}{2}\frac{d}{dV}(W^2)[/itex]<br /> <br /> ...you will then have a first order, <b>separable</b> ODE for [itex]W[/itex]...which I'm sure you know how to solve!<img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":wink:" title="Wink :wink:" data-smilie="2"data-shortname=":wink:" /> <br /> <br /> P.S. This is a common trick, so it's worth remembering!<img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />[/tex]
  • · Replies 20 ·
