Solving Trajectory Problem: Initial Speed, Time, & Height
  • Thread starter Thread starter PhilCam
    Trajectory
The problem involves analyzing the trajectory of a football kicked towards a goal post, with specific parameters including initial speed, angle of projection, and height of the goal post. The discussion focuses on calculating various components of the motion, such as horizontal and vertical speed, time of flight, and height at which the ball crosses the goal post.
  • Participants discuss the calculation of horizontal and vertical components of initial speed, as well as the time taken for the ball to reach the goal post. Questions arise regarding the height of the ball when crossing the goal post and the magnitude of its speed at that point.
Some participants have provided calculations and formulas to assist with the problem, while others express uncertainty about specific steps and results. There is acknowledgment of correct mathematical procedures, but discrepancies in expected outcomes lead to further questioning.
Participants are working under the assumption that air resistance and friction are negligible, and they are adhering to the constraints of the problem as presented. There is an ongoing exploration of potential errors in calculations or answer keys.
PhilCam
A college regulation goal post has a horizontal ball at a height of 3.048 m from the ground. A kicker attempts a field goal at a distance of 30 m from the goal posts. The initial speed of the ball is 19 m/s making an angle of 40 degrees above the horizontal. The plane of trajectory is perpendicular to the plane of the goal posts. Neglect friction and air resistance.
a) The horizontal component of the intial speed of the ball is:
b) The vertical component of the inital speed of the ball is:
c) The time it takes for the ball to cross the plane of the goal posts is:
d) The ball crosses the plane of the goal posts at a height of:
e) The magnitude of speed of the football as it crosses the plane of the goal posts is:
Well I have found (A) using 19m/s X cos 40 degrees and part (B) using 19 m/s X sin 40 degrees.
The answers are 14.55 m/s and 12.2 m/s respectively. For part C, I just took 30 m divided by the horizontal component of 14.55 and the answer was 2.06 seconds which I believe is correct.
For part D and E, I am unsure of how to proceed. I thought maybe 2.06seconds X 12.2 m/s but the answer seemed way too high. Any help would be greatly appreciated.
d) Use the formula
y = v*sinθ*t - 0.5*g*t^2. From c) you know the time. Find y.
e) Using v = v*sinθ - g*t, find the vertical component of the velocity after time t. Horizontal component remains constant. Find the resultant of these two velocities.
Thank you for the help.
Using your second formula:
V=19*(sin 40) - 9.8(2.016)
V= 12.213 - 19.757
V= -7.544
Magnitude = Square root (-7.544^2+14.55^2)
M = Square root (56.912+211.703)
M=16.389
It is telling me the answer should be 16.6.
I have re-done this equation a couple times, is there a math error or an answer key error?
Again, thank you for the help
Your math is correct.
  • · Replies 38 ·
  • · Replies 19 ·
