Find parametric equations for the tangent line at the point
The discussion revolves around finding parametric equations for the tangent line at a specific point on a curve defined by the equations x = cos(t), y = sin(t), and z = t. The point of interest is given as (cos(4π/6), sin(4π/6), 4π/6).
  • Exploratory, Assumption checking
  • Participants discuss the derivative of the curve and the choice of parameter t for evaluating the tangent line. There is uncertainty about the correct value of t to use and the implications of that choice.
Some participants have provided guidance on how to determine the appropriate value of t by comparing the original parametric equations with the given point. There is acknowledgment of confusion regarding the choice of t, but no consensus has been reached on the final approach.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a focus on ensuring that the chosen parameter aligns with the specified point on the curve.
undrcvrbro
[tex](\cos(\frac{4 \pi}{6}) ,\sin(\frac{4 \pi}{6}) ,\frac{4 \pi}{6}) )[/tex]
on the curve
[tex]x=\cos t,\ y=\sin t, \ z=t[/tex]
Took the derivative
r'(t)=( -sint, cost, 1)
Here's where I start to fall apart...I'm not sure what to do...but..is this close...
cos(4pi/6)= -1/2
r'(-1/2) = (-sin(-1/2), cos(-1/2), 1)
so,
x= (-1/2) + (-sin(-1/2))t
y= (sin(4pi/6)) + (cos(-1/2)t
z= 4pi/6 + t
So where did I go wrong? I hope I'm not that far off. If anything needs clarified, please ask.
on the curve
Took the derivative
cos(4pi/6)= -1/2
based on what you have said why choose the point t = -1/2? i would think t = 4.pi/6 is a better choice ;) and what the question asks for
undrcvrbro said:
so,
z= 4pi/6 + t
then once you have the tangent vector r', and the point of the curve say p, the equation o the tangent line will be
f(s) = s.r'+p
Thank you! I have the right answer, but I don't understand why you chose t= 4pi/6..can you explain?
compare you original parametric equations with the point you are asked to evaluate it at, this gives you the correct t value
Ohhh. Yikes, I can't believe I didn't notice that! Thanks again!
