Some confusion between radiation and conduction
The discussion revolves around the mechanisms of heat transfer, specifically focusing on conduction and radiation. Participants explore the conditions under which radiation may play a role in thermal applications, particularly in scenarios involving metal containers and varying temperatures.
  • One participant asserts that the heating of the inside surface of a metal container filled with hot water is due to conduction, but questions whether radiation is also involved.
  • Another participant humorously questions the material of the container, suggesting it might be uranium.
  • A different participant clarifies that electromagnetic radiation, which includes visible light and infrared, is a valid mechanism of heat transfer and is always present, though often negligible in many situations.
  • One participant expresses confusion about why radiation through air is considered negligible at temperatures below several hundred degrees Celsius and asks if there is a specific temperature at which radiation becomes significant.
  • A scenario is presented involving a bunsen flame applied to a metal rod, questioning whether conduction or radiation is the main transfer process when there is no air space between the flame and the rod.
  • Another participant provides a formula for calculating heat flux from radiation and suggests that while radiation may not be negligible, it is not the dominant mechanism for temperature differences below a hundred degrees.
Participants express varying views on the significance of radiation in heat transfer, especially in relation to conduction. There is no consensus on the conditions under which radiation becomes significant, and the discussion remains unresolved regarding the comparative roles of conduction and radiation in specific scenarios.
Participants mention specific temperature thresholds and conditions under which radiation may be considered negligible, but these points remain debated without definitive conclusions.
klng
"I pour hot water into a metal container. The inside surface of the container gets hot."
It is quite clear the inside surface gets hot due to conduction (criteria of process is satisfied).
What i am not so sure about is whether radiation is involved. Theory and some gut instinct tells me there should be. But if this were the case, then won't radiation be present (though it may not be the doninant process however) in all thermal applications which involve conduction as well?
Thanks in advance for the guidance.
Science news on Phys.org
Is the container made out of uranium lol?
king is referring to electromagnetic radiation, which includes visible light, infrared, etc., and which is a valid mechanism of heat transfer. Yes, radiative heat transfer is always present, though it can be assumed to be negligible in many situations. It's generally negligible for the cases of heat transfer through metal or heat transfer through air between objects at less than several hundred °C, for example.
Hi Magpes,
Thanks for the reply.
I can understand why you said radiation through metals is negligible, as there are many mobile electroons which will make conduction the predominant process.
But i can't fully understand why radiation through air is negligible if the temp is less than several hundred degC. Is there a benchmark temp when radiation becomes significant?
Also take a look at the following example:
A bunsen flame is applied at one end of a metal rod. Note the flame is directly touching the metal rod (ie no air space between flame and the rod). Is the main transfer process between flame and metal rod conduction or radiation?
Had there been an air space in between,we can argue it is radiation, since air is a bad conductor of heat. But w/o the air space, it gets kinda puzzling. But if i were to make a bet, i will still bet my money on radiation.
It's something you can calculate: the heat flux from radiation is [itex]\sigma \epsilon (T^4-T^4_\infty[/itex]), where [itex]\sigma=5.67\times 10^{-8}[/itex] and [itex]\epsilon[/itex] is the emissivity. Compare to convection, [itex]h(T-T_\infty)[/itex], where the convection coefficient can be around 10 W m-2 K-1 for natural convection or much higher for forced convection. I shouldn't have said negligible, though; let's say instead that radiation isn't the dominant mechanism for temperature differences less than a hundred degrees.
  • · Replies 16 ·
15K
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 17 ·
