Efficient File Manipulation and Selection with Awk Command: Step-by-Step Guide
  • Thread starter Thread starter confi999
The discussion focuses on efficient file manipulation using the Awk command to handle a large number of files named sequentially from 'file000001.txt' to 'file008000.txt'. The user seeks to delete files from 'file003001.txt' to 'file008000.txt' and extract specific data from the remaining files based on column values. The community suggests using shell commands for deletion and filtering instead of Awk, highlighting that the command 'rm file00[3-8]?.txt' is more efficient for file removal, while Awk can be employed for data extraction from the remaining files.
  • Basic understanding of file naming conventions in Unix/Linux environments
  • Familiarity with the Awk command for text processing
  • Knowledge of shell commands for file manipulation
  • Understanding of column-based data extraction techniques
  • Learn advanced Awk scripting for data extraction and manipulation
  • Research shell command techniques for batch file deletion
  • Explore the use of regular expressions in file selection
  • Investigate performance optimization for handling large file sets in Unix/Linux
System administrators, data analysts, and developers who need to efficiently manage and process large sets of files using command-line tools.
confi999
Hello,
I have about 8000 files in a directory all having names like
file000001.txt
file000002.txt
file000003.txt
file000004.txt
file007999.txt
file008000.txt
Now I need to do 2 things:
1. I found out that I don't actually need the data from the files whose names are above 'file003000.txt'. So I want to delete the 5000 files from 'file003001.txt' through 'file008000.txt' using awk. (I don't know how to do this part) I will then take the values of column 3 of each of the remaining files if column 1 == 20 and put these in 'select.txt' file (I know how to do this part).
2. I believe it is possible (but I am not being able to do it) even without deleting those 5000 files to write an awk command that will only take files which has values less than / equal to 'file003000.txt' and do the latter part on them i.e. taking the values of column 3 of each file if column 1 == 20 and put these in 'select.txt' file. In other words it is something like if VARIABLE<=3000 in 'file00VARIABLE.txt' consider it otherwise ignore it.
How can I do both of the above using awk (one liner preferred than scripts).
Any help is highly appreciated. Thank you.
Technology news on Phys.org
Why use awk? Just use the command line. In csh/tcsh,
rm file00[3-8]?.txt
Don't use awk to do the filtering that is easier done at the shell level.
awk -f script.awk file00[0-2]?.txt
  • · Replies 20 ·
12K
13K
9K
  • · Replies 30 ·
12K
