Calculating CFM Over a Room Surface
  • Context: Undergrad
  • Thread starter Thread starter Mike1984
    Cfm Surface
The discussion centers on calculating the cubic feet per minute (CFM) of airflow over a surface in a room, specifically near the floor, with an exhaust vent as the only airflow outlet. The formula presented, O = c (10*x^2 + A) Vx, is questioned for its accuracy, as it produces excessively high results. Participants agree that the distance (x) from the exhaust duct should inversely affect the CFM, suggesting a potential need for logarithmic adjustments in the formula to accurately reflect airflow distribution.
  • Understanding of HVAC principles and airflow dynamics
  • Familiarity with CFM calculations and exhaust systems
  • Knowledge of mathematical modeling in fluid dynamics
  • Experience with airflow measurement techniques
  • Research logarithmic functions in airflow calculations
  • Study the impact of distance on airflow distribution
  • Explore alternative formulas for calculating CFM in HVAC systems
  • Learn about minimum capture velocity and its significance in exhaust design
HVAC engineers, airflow specialists, and anyone involved in designing or optimizing ventilation systems will benefit from this discussion.
Mike1984
I have a tough question. I'm trying to calculate the cfm over a surface in a room. assuming that the only airflow out of the room is an exhaust vent. I need to know how to calculate that CFM for the surface near the floor of the room, depending on its distance from the exhaust duct and the cfm inside the duct. I have one formula, but it seems incorrect to me:
O = c (10*x^2 + A) Vx (where Vx is V sub x)
O is the exhaust volume (at the surface in the room, I believe), cfm
x is the distance from the center of the hood on the exhaust duct to the surface in question, ft
A is the hood face area, not including the flange, sq ft
Vx is the minimum capture velocity, fpm.
c is a multiple for flanged or unflanged hood, .75 for flanged, 1 for unflanged.
this formula produces results that are way too large. shouldn't the portion with the x be inversely effecting the results (divided) rather than directly effecting them (multiplied, whatever).
Any input would be appreciated. thanks.
I'm an HVAC engineer, but I'm really not sure what you are trying to do here. Are you trying to figure out how airflow gets distributed through a room? I don't understand what you men by "surface near he floor of the room". Do you mean hypothetically if you held up a piece of paper edge-on to the flow, what would the flow be? I don't see anything that says how big this hypothetical surface is. I've never seen that equation before. Where did you get it?
Mike1984 said:
...this formula produces results that are way too large. shouldn't the portion with the x be inversely effecting the results (divided) rather than directly effecting them (multiplied, whatever).
Yes. The distance should inversely effect the results with an increase in distance there should be a decrease in CFM at the surface. Are you missing a Log or an antilog in that formula? It should work almost like a sound calculation.
  • · Replies 19 ·
11K
  • · Replies 44 ·
