Projectile Motion - Particle Acceleration
The problem involves projectile motion with a particle experiencing acceleration in both the x and y directions. The initial conditions include a vertical velocity of 5.6 m/s and a horizontal velocity of 0 m/s, with a horizontal acceleration of 2.1 m/s² and gravitational acceleration of 9.8 m/s². The goal is to determine the time at which the particle travels at an angle of 58° with respect to the horizontal.
  • Participants discuss relevant equations for two-dimensional accelerated motion and attempt to relate the velocity components to the angle of 58°. There is an exploration of how to express final velocities in terms of time and the initial conditions provided.
Some participants are attempting to clarify their understanding of the relationships between the velocity components and the angle. Guidance has been offered on how to set up equations based on the angle and the components of velocity, but there remains confusion regarding the time variable and the relationships needed to solve the problem.
Participants express uncertainty about the initial time value and how it relates to the problem setup. There is a suggestion to draw a diagram to visualize the velocity components and their relationships.
Osbourne_Cox
1.Please note that in the following problem the particle has accelerations in both the x- and the y-directions. Therefore the x and y components of velocity keep changing. Initially (at time t = 0) a particle is moving vertically at 5.6 m/s and and horizontally at 0 m/s. The particle accelerates horizontally at 2.1 m/s2 . The acceleration of gravity is 9.8 m/s2 .
At what time will the particle be traveling at 58◦ with respect to the horizontal? Answer in units of s.
No clue!
What are the relevant equations for accelerated motion in 2-dimensions?
Vxi=Vicostheta Vyi=Visintheta
Dx=Vxt
d=1/2(Vi+Vf)t
a=(Vf-Vi)/t
d=Vi(t)+1/2at^2
Vf^2=Vi^2+2ad
That's all I know
Good. That's all you need. Look at the third equation. Solve it for vf in terms of the other quantities. Write two equations, one for the horizontal direction and one for the vertical direction
vxf = ...
vyf = ...
I'm sorry I don't understand
Questions like this are ultimately about asking you to find a solution to a system of equations. The hard part is finding the equations to solve. The easy part is solving them.
Recall the techniques for solving a system of equations. You can substitute equalities (so, if a+c=3, and a/2=1, you could then restate the second equation as a=2, and substitute 2 in the first equation, allowing you to solve for c), add and subtract equations to eliminate variables, and so forth.
First, get clear on the problem. Draw a diagram. At the time you want, the vector of the particle will be at a 58 degree angle from the x-axis. What will the x and y components of that vector represent?
Remember that, if we're graphing velocity, tan θ = (velocity y) / (velocity x).
So the angle in the question is giving you some key information about the relationship between velocity-y and velocity-x at that time. Make that relationship as clear as possible. We know θ, so you can state the relationship much more clearly.
You want to find the value of t. How can we manipulate those equations, and what we know about the relationship of the velocity-y to velocity-x, to give us an equation in terms of t?
You know the values of θ, the initial velocity-x, the acceleration-x, the initial velocity-y, the acceleration-y. We do not know the final velocity of x or y, and we do not know displacement of the particle. We want to find the time.
I am still very confused.
Third equation
a=(Vf-Vi)/t
Solve for vf in terms of the other quantities.
Is there anything in all of the above that you don't understand?
No, after reading it over a few more times I think I understand it better...but what I don't get is that the t value we are using is a zero? No other t is given...? Thats where I am confused.
Set the time aside for a moment. When the particle is traveling at 58o with respect to the horizontal, what relation is true between the velocity components?
I have no clue...I'm sorry, I'm terrible at this... :(
Draw a right triangle for the velocity vector. The right sides are the x and y components, The angle the vector makes with respect to the x-axis is 58o. What is a relation that has vx, vy and 58o? If you are still clueless, you need to review and learn how to resolve a vector into its components.
I've seen these before:
This has all three, but I've never used it yet:
There is always a first. At the time you are looking for, the angle is 58o and on the right side of this equation you have Vyf / Vxf, the ratio of the final velocity components. So if you can express Vxf and Vyf as a function of time (with "t" in it), then you can solve that equation for t. To do that start with the third equation written twice, one for the x direction and ine for the y direction.
  • · Replies 18 ·
