Prove Complex Integral is Purely Imaginary
The discussion revolves around proving that the integral of the conjugate of an analytic function multiplied by its derivative over a closed curve is purely imaginary. The subject area is complex analysis, specifically focusing on properties of analytic functions and integrals in the complex plane.
  • Participants explore the expression of the integral by breaking down the function into its real and imaginary components. There is an attempt to verify the real-valued nature of certain integrals derived from the original expression. Questions arise about the implications of parametrizing the curve and the nature of differentials in complex analysis.
Participants are actively engaging with the problem, sharing their attempts to manipulate the integral and clarify the relationships between the components involved. Some guidance is offered regarding the expression of differentials and the use of Cauchy-Riemann equations, but no consensus has been reached on the resolution of the problem.
There are indications of uncertainty regarding the relationship between analytic functions and their properties, as well as the handling of complex differentials in the context of the integral. Participants express confusion about the implications of certain mathematical manipulations and the assumptions underlying the problem.
owlpride
Assume that f(z) is analytic and that f'(z) is continuous in a region that contains a closed curve [tex]\gamma[/tex]. Show that
[tex]\int_\gamma \overline{f(z)} f'(z) dz[/tex]
If f(z) is holomorphic on the region containing a closed curve [tex]\gamma[/tex] or if f(z) has a primitive (we have not yet established a relationship between these two properties), then
[tex]\int_\gamma f(z)dz = 0.[/tex]
And while we did not prove that analytic functions are holomorphic, that's not hard to verify if necessary.
If we let [tex]f(z) = u(z) + i v(z)[/tex], where u and v are functions from the complex plane to the real line, then
[tex]\int_\gamma \overline{f(z)} f'(z) dz = \int f(z) f'(z) dz - 2 i \int v(z) f'(z) dz = 0 - 2 i \int_\gamma v(z) f'(z)dz[/tex]
So I have to verify that the latter integral is real valued, and this is where I am stuck. I could parametrize [tex]z = \gamma(t)[/tex] where [tex]t \in [0,1][/tex] but I am not sure that helps me in any way.
[tex]- 2 i \int_\gamma v(z) f'(z)dz = -2 i \int_0^1 v(\gamma(t)) f'(\gamma(t)) \gamma'(t) dt = 2 i \int_0^1 v'(\gamma(t))f'(\gamma(t))\gamma'(t) \gamma'(t) dt[/tex]
(The last step comes from integration by parts, with one term = 0 because gamma is a closed curve.)
Is there any reason to believe that this last integral is real-valued?
I am not sure what you did here.
If [itex]f(z) = u(z) + iv(z)[/itex], then [tex]\overline{f(z)} = u(z) - i v(z)[/tex] and [itex]f'(z) = u'(z) + i v'(z)[/tex], so<br /> <br /> [tex]\begin{align*}\int_{\gamma} \overline{f(z)} f'(z) dz &= \int_{\gamma} (u(z) - i v(z)) (u'(z) + i v'(z)) dz \\<br /> &= \int_{\gamma} (u(z) u'(z) + v(z) v'(z)) dz +i \int_{\gamma} (u(z) v'(z) - v(z) u'(z)) dz \end{align*}[/tex]<br /> <br /> All of [itex]u(z)[/itex], [itex]u'(z)[/itex], [itex]v(z)[/itex], and [itex]v'(z)[/itex] are real, so if you can show that the first integral is zero then you're done.[/itex]
jbunniii said:
[tex]\begin{align*}\int_{\gamma} \overline{f(z)} f'(z) dz <br /> &= \int_{\gamma} (u(z) u'(z) + v(z) v'(z)) dz +i \int_{\gamma} (u(z) v'(z) - v(z) u'(z)) dz \end{align*}[/tex]
But [tex]dz[/tex] is not real. Does that mess with the value of the last integral?
Thanks for your thoughts!
You seem to be having a hard time finding a good expression for f'(z)*dz. You can do it several ways. (df/dz)*dz=df. If f(z)=u(z)+iv(z) and z=x+iy, that makes it (u+iv)_x*dx+(u+iv)_y*dy. (Underscores are partial derivatives). Or you could use f'(z)=(u+iv)_x or f'(z)=(1/i)*(u+iv)_y and dz=dx+idy. You can show they are all equal with Cauchy-Riemann. Now just collect the real and imaginary parts and figure out whether they are exact differentials. Take it from there.
  • · Replies 16 ·
