Thread Closed
Scale Height for Planets
Share Thread Thread Tools
Oct8-09, 10:55 AM   #1
I want to try to find the scale height of a planet using H=kT/Mg, where H is the scale height, k is the Boltzman constant, T is the surface temperature, g is the acceleration of gravity, and M is the mean molecular mass.
I am having a great deal of trouble understanding M and how to calculate it. In my handout, it says that it should be in units of nitrogen masses. On wikipedia it says that it should be in kg. Wikipedia also refers to mean molecular mass as being defined in terms of the unified atomic mass unit. Augh...
I know that the composition of the atmosphere is similar to ours, 78% nitrogen and 21% oxygen, but I don't know the density which prevents me from just plugging it into the ideal gas law.
Do you think that when my handout says "in SI units of nitrogen masses" it means molar masses or just the mass of one atom?
I think in the end it is safe for me to assume that the density is the same, as the planet has similar characteristics to Earth in it's radius and mass. I would really like to figure this out independent of any unnecessary assumptions though. Thanks for any help you can provide!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Oct8-09, 08:41 PM   #2
Mentor
Quote by Breedlove View Post
I want to try to find the scale height of a planet using H=kT/Mg, ...
It would be the mass of one molecule (not necessarily a single atom, but definitely not the molar mass.)
Just FYI, when a formula has k in it, they are referring to single atoms or molecules. When they want you to use molar quantities, the gas constant R=NAk is used instead.
Thread Closed
Thread Tools
Similar Threads for: Scale Height for Planets
Thread Forum Replies
Spring Scale, the force will the scale read? Introductory Physics Homework 2
compactification scale versus decompactification scale Beyond the Standard Model 0
Re: Higgs Particles & Scale-Invariant Metrics & Breaking Scale Symmetry General Physics 4
Influence of planets on planets General Astronomy 3
