How Can Variables l and T Be Plotted to Determine k from a Graph's Slope?
The discussion revolves around how to plot the variables \( l \) (lambda) and \( T \) to determine the constant \( k \) from the slope of a linear graph. The original poster seeks clarification on the relationship between these variables and the constants involved in the graph's slope and intercept.
  • Participants discuss the appropriate way to graph \( l \) as a function of \( (1/f)(T/u)^{0.5} \) and question how this relates to the slope representing \( k \). There are inquiries about whether squaring the expression is necessary to avoid non-linear results.
Several participants have provided insights into how to structure the graph, suggesting that plotting \( l \) against \( (1/f)(T/u)^{0.5} \) will yield a linear relationship. Others have mentioned the possibility of using logarithmic transformations to achieve linearity. The discussion is active, with various interpretations and clarifications being explored.
Participants note the importance of knowing the constants \( f \) and \( u \) to accurately plot the graph. There is also mention of the challenges faced in understanding the graphing process, particularly in relation to the laboratory manual's explanations.
General_Sax
How should the variables ( l and T) be plotted to obtain k from the slope of a linear graph? Identify (write out) the constants correstponding to the slope and intercept of the linear graph.
l = lambda
l = (k/f)*(T/u)^0.5
k^2 = [ (f^2)*(u) ] * [ (l^2)/T ]
(l^2)/T = x
(f^2)* u = m
K^2 = mx + 0
b = 0
You really want to graph l as a function of (1/f)*(T/u)^0.5
The slope, if you obtain the graph of a line, will be k.
I truly don't understand how that function's slope represents k. Does the removal of k somehow allow it to represent the slope?:confused:
A line crossing the origin can be represented with y = m*x. I used the "*" to show multiplication.
Your equation is l = (k/f)*(T/u)^0.5, which you may rewrite as l = k*(1/f)*(T/u)^0.5. In this equation, l corresponds to y, k corresponds to m, and (1/f)*(T/u)^0.5 correponds to x.
Oh, that's so simple, yet so elusive. Thanks so much for your help. One last question: should I square the whole expression, so that I don't get a curve from (T/u)^0.5?
Based on the description you gave, No.
You are expecting a linear relationship for which your horizontal axis is for values of THE EXPRESSION, (T/u)^0.5 ; that expression IS your independent variable, composed of T and u.
What the others are saying is that you plot [itex]y= \lambda[/itex] on one axis and the values of [itex]x= (1/f)\sqrt{T/u}[/itex] on the other. That way your graph will be y= kx with k as the slope. Of course, you have to know f and u to do that.
Another thing you could do, and a fairly common way to get a linear graph from non-linear data, is to take the logarithm of both sides and plot that.
[tex]log(\lambda)= log((k/f)*(T/u)^0.5)= 0.5 log(T)+ log(k)- log(f)- 0.5log(u)[/itex]<br /> Plotting [itex]log(\lambda)[/itex] against log(T) will give you a straight with slope 1/2 and log(k)- log(f)- 0.5log(u) as y-intercept. Assuming that you know f and u, that will tell you k.<br /> <br /> Does anyone remember "log-log graph paper" or am I showing my age here?[/tex]
You people are so helpful. Much better than my TA, and you aren't even being paid!
So, in general, if I'm given two variables and I need to graph the relationship between them I do:
a) use one as the y-axis and one as the x-axis.
b) use whatever method I need to in order to have a constant infront of the x-axis variable.
c) remember that even if certain values aren't plotted onto the graph, they are still part of the expression
Right?
General Sax, if your TA's are helping you with this then what they are good for is uncertain. Do you at least have the explanation and description of the process for this kind of graphing in your laboratory manual?
HallsofIvy - I also remember log-log paper; and semi-log paper; and two and three cycle log paper; and polar coordinate paper.
Those three questions, General Sax:
Yes.
What exactly do you mean? Maybe.
That means nothing. What kind of values are and are not plotted? Why?
You need to identify your chosen variables; sometimes one of your variable is composed of other variables.
We have two TA's in my physics lab, but my physics lab is divided into two sections, so the TA's are also 'split'. The TA for my section is very unfriendly, I feel he has a "this is beneath me" attitude. He always makes me feel so stupid. The other TA is nice and friendly, but always has such a large queue for questions that I often don't have the time to ask him questions ( we have to hand in our lab reports at the end of the lab).
Yes, but it reads to me like programming syntax, and I always have had difficulty learning that way. I preform much better in a class or tutorial environment.
re-write the equation so that I have the form y = mx + b. where m and b are compositions of variables.
Your response was helpful.
Let's say that the variables were l ( l = lambda ) and u.
l = (k/f)*(T/u)0.5
I could plot the graph using:
y = l
x = 1/ (u)0.5
thus:
m = (T/u)0.5 * 1/f
Thanks again for any time you contribute to me. I really do appreciate it. Happy thanksgiving!
Edit: m (slope) = T0.5 * k/f
  • · Replies 0 ·
