Is There a Semiconductor to Regulate High-Voltage Super Capacitor Output?
  • Thread starter Thread starter taylaron
    Semiconductor
The discussion centers on the need for a semiconductor or compound capable of regulating the output of a high-voltage super capacitor (100,000+V, 0.1uF) without significant energy loss as heat. The user explores the potential of using a non-conductive polymer impregnated with single-wall carbon nanotubes (SWCNTs) to achieve partial conductivity while minimizing heat generation. The goal is to maintain a stable output voltage in the range of 1-200V, addressing the limitations of traditional transistors in this application.
  • Understanding of high-voltage capacitor behavior
  • Knowledge of semiconductor physics and materials
  • Familiarity with carbon nanotube properties and applications
  • Basic principles of electrical conductivity and resistance
  • Research the properties and applications of single-wall carbon nanotubes (SWCNTs)
  • Investigate the design and functionality of variable resistors and their use in high-voltage applications
  • Explore advanced polymer composites for electrical applications
  • Study the principles of energy loss in conductive materials and methods to minimize heat generation
Electrical engineers, materials scientists, and researchers focused on energy storage solutions and high-voltage applications will benefit from this discussion.
taylaron
Hi, I have a super capacitor that is charged at 100,000+V at 0.1uF. Naturally it wants to give of its energy instantaneously in a spark; but I am trying to find a compound or semiconductor that can regulate the output of electricity from this capacitor without wasting the majority of the energy as heat.
I've envisioned a semiconductor that only let's x current through with a source at 100,000+V, but once the cap voltage drops low enough, there wouldn't be enough voltage to flow across the semiconductor. This "wastes" the rest of the energy in the cap which defeats the purpose.
I'm asking if there is an existing compound or semiconductor that can regulate its conductivity in a wide enough range to make the output voltage low enough at a near constant rate to be useful (~1-200V range).
A transistor comes to mind, but to my understanding, its range of conductivity is not wide enough to be 'useful'.
So, can one take a non conductive polymer and impregnate it with x percent lengths of nano scale ballistic conductors (metallic single wall carbon nano tubes) and achieve partial conductivity but without the loss of a lot of heat? To my understanding, since the electrons can't travel through the polymer the only route to travel through is the carbon nano tubes which are near perfect conductors (hence the ballistic conduction).
Or, would the electrons traveling through the SWCNT's "collide" with the molecules of the non conductive polymer and create friction thus heat? (although I still don't understand how electricity would be able to flow at all in those areas because it is an open circuit thus no current and no friction).
I see it like a bolt of lightning where there are many many splits from the main discharge path, but they stop because they don't have a path to ground. Similar to the lengths of CNT's empregnated in the polymer woud act as the ionized air particles in a lightning bolt. The current would only flow through the sections of CNT's that are all touching one another creating a path for the electrons to flow.
Where the electrons flow through there would be a direct path to the other side of the polymer, there would be incredibly little resistance creating a "single position valve for electrons" without the loss of energy through collisions (heat). the conductivity can vary with the concentration of CNT's as long as the polymer is a homogeneous mixture.
Am I correct?
Briefly explained here: http://www.entegris.com/Resources/Images/20257.pdf
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 19 ·
