Gallium nitride-how to produce?
  • Thread starter Thread starter kimmylsm
The discussion focuses on the production of gallium nitride (GaN) through a wet chemistry method, specifically using Gallium Chloride and Lithium Nitride combined with a small amount of amine. The optimal temperature for this process is approximately 290°C, which yields nanocrystalline Ga with a wurtzite structure. Post-synthesis, the material should be dispersed in Chloroform or Toluene after undergoing ethyl reflux cleaning. The importance of consulting existing literature on the subject is emphasized for further understanding.
  • Understanding of wet chemistry techniques
  • Familiarity with phase diagrams and temperature control
  • Knowledge of nanocrystalline materials and their properties
  • Experience with chemical solvents like Chloroform and Toluene
  • Research the synthesis of gallium nitride using Gallium Chloride and Lithium Nitride
  • Study the effects of temperature on the phase diagram of GaN
  • Explore the properties and applications of nanocrystalline materials
  • Read scientific papers on wet chemistry methods for semiconductor production
Chemists, materials scientists, and researchers interested in semiconductor fabrication and the production of gallium nitride for electronic applications.
kimmylsm
How to prepare chemically, i mean liquidly, gallium nitride GaN beside using ammonia which is not pratical? nitrogen is tried but not very successful.
there is a way... via wet chemistry... use Gallium Chloride and Lithium Nitride with some small amount of amine then add heat check a phase diagram to see how high you have to go , but i believe 290 C is good, however this is a recipe for nanocrystalline Ga with wurtzite structure... and should be dispersed in Chloroform or Toulene after being cleaned by an ethyl reflux. There are plenty of papers out there on "how to" ... don't be lazy... read them!
22K
  • · Replies 0 ·
