Diffusion problem with concentration
The discussion revolves around a diffusion problem related to the concentration of a substance and its adherence to the diffusion equation. Participants are exploring the relationship between concentration gradients and the rate of substance movement within a defined region.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to relate the diffusion equation to a mass balance approach and are considering integrating concentration over a volume. There are questions about the properties analogous to density and specific heat capacity in the context of concentration. Some participants express confusion about how to initiate the problem and the necessary steps to take.
There is a range of attempts to clarify the problem, with some participants suggesting the use of Fick's law and the divergence theorem. Others are still grappling with the foundational concepts and expressing uncertainty about how to proceed with their calculations.
Participants mention a lack of familiarity with the concepts of concentration in relation to diffusion, and there are references to similar problems involving temperature, indicating a potential struggle with transferring knowledge across different contexts.
tigger88
Show that concentration of a substance obeys the diffusion equation if the rate at which substance leaves a region is proportional to the concentration gradient.
Diffusion equation: [tex]\nabla[/tex]2[tex]\phi[/tex] = (1/a) (d(phi)/dt)
where Phi is a function of r, t.
I'm having trouble even starting this question. I think I have to integrate concentration (C(r,t)) over a volume to get total amount of substance, but there might be some other constants I have to throw in as well... and I'm not sure what they would be...
I have a vaguely similar solved example to do with temperature, but I'm having trouble relating it to concentration.
I don't really know where to begin! I'm not looking for a full worked solution, but could someone just give me a push in the right direction?
Thanks very much!
The equations for temperature and concentration are exactly equivalent (at this level), so feel free to adapt the temperature problem.
Perhaps you could perform a mass balance on some arbitrary volume element.
In my temperature problem, density and spec. heat capacity are used. What are the corresponding properties I should use for concentration? Also in that problem the solution integrates the product of density, Cp and the temperature function over a small volume V. Obviously this gives Q (heat energy), but what would it give for the concentration question?
I should probably know this, but I get a mental block whenever concentration is involved with anything.
Thanks for your help!
You should probably review http://en.wikipedia.org/wiki/Fick%27s_law_of_diffusion" concepts. Regarding the integration question: the units are a good indication of the physical interpretation (e.g., if you end up with moles, you're dealing with the total amount of the substance).
I'm sorry, but I'm still completely in the dark about how to start this question. Forget the fact that I have a vaguely similar temperature question, I don't understand it anyway and I'm getting overly confused about where the similarities/symmetries lie.
My best guess of a vague procedure for this (which I can't actually attempt because I don't know precisely what to begin with) is to take the integral of something involving concentration (maybe some other stuff too?) over some volume V, then differentiating wrt time, using the divergence theorem to relate it to a volume integral, and equating this final expression with the initial one. Is that the right idea?
Do I start off by finding the integral (over volume V) of concentration, or do I find the integral of the product of concentration and some other stuff (if so, what's the other stuff?)?
Also, in order to find the derivative wrt time, is there something similar to the heat flow equation: dQ/dt = kA(dT/dx) that I could use?
Thanks again for the help, clearly my brain isn't working.
Sure, you could integrate and then use the divergence theorem. You could also (perhaps more easily) consider just a differential element, assume the rate law specified in the problem description, and equate the input flow rate to the change in concentration within the element.
The matter equivalent to Fourier's Law is Fick's First Law.
  • · Replies 19 ·
