Rotation angle from angular rate
The discussion revolves around the challenges of obtaining accurate rotation angles from an inertial sensor that provides only angular rate and acceleration data. Participants explore issues related to drift in the calculated rotation angle when the sensor is stationary, and seek methods to mitigate this drift.
  • Exploratory, Technical explanation, Debate/contested
  • Chathuri describes the integration of angular rate to calculate rotation angle and notes continuous drift when the sensor is stationary, suggesting it may be due to integration errors.
  • Some participants propose that drift is an intrinsic issue with rate sensors and suggest methods such as periodic resetting to a fixed point or using an external reference to correct for drift.
  • There is a discussion about the need for an external reference to accurately determine the sensor's orientation, as relying solely on acceleration readings may not provide sufficient information.
  • Chathuri provides details about the specific sensor used (ADIS16350) and the method of calculating rotation angle, including the correction of gyroscope bias and the equations employed.
  • Cleonis questions the implementation of the integration process and highlights the importance of understanding the sensor's behavior in relation to Earth's rotation when stationary.
  • Chathuri expresses uncertainty about conventional methods to deal with drift, indicating a lack of experience with sensor technology.
  • Cleonis acknowledges a lack of clarity on the source of drift and expresses empathy towards Chathuri's situation, indicating a shared struggle in addressing the problem.
Participants do not reach a consensus on a specific method to resolve the drift issue, and multiple competing views regarding the nature of the problem and potential solutions remain present throughout the discussion.
Limitations include the potential for systematic bias in the integration process, the dependence on the sensor's calibration and environmental conditions, and the unresolved nature of the drift's source.
chathuri
Hi,
I am using an inertial sensor to obtain rotation angle. However the sensor only gives the angular rate and acceleration. Therefore I integrated the angular rate to obtain the rotation angle in real time. However, I noticed that if I keep the sensor stationary, the rotation angle starts to increase or decrease slightly but continuously. I believe this has somethin to with a drift caused by the integration.
Would anyone know how I could fix this issue. I am very knew to this and was hoping you could help me out.
Thankyou!
Chathuri
It's an intrinsic problem of all rate sensors. (It's why 727s have a window above the cockpit to see the stars)
Best option is to be able to reset to a fixed point periodically - eg by having a separate sensor that detects when it's level.
Second best is to model the drift and apply a correction - but the drift is likely to be temperature dependent and may differ from one unit to the next.
Thanks for your reply. But I need to clarify. Do you mean I should check if the sensor is stationary (probably see if the acceleration is close to 0) and then keep the previous value of the rotation angle without integration?
If acceleration <0.01 then theta = theta_prev
Thankyou!
Chathuri
If you have an acceleration sensor then when it reads zero you don't know that it is in any particular angle.
To o this accurately you need an external reference, such as a separate level sensor that triggers when the device is exactly horizontal and use this to reset your angle integrator. Or you might be able to get a reset when, for instance, a shaft passes some particular point.
chathuri said:
Hi,
You have not described in any way how you have implemented the integration. What kind of device performs the integration? Is the device such that a systematic bias may occur? If so, how large a systematic bias? Can it account for the drift?
You are not providing enough clues to give me something to work with.What do you mean with: 'When I hold the sensor stationary'? For instance, if a rotation sensor is stationary with respect to the Earth, then it will register the Earth's rotation rate. (Depending on the type of rotation sensor the sensor's orientation with respect to the Earth's axis will also be a factor in how much rotation is registered.)
High performance rotation sensors are easily sensitive enough to register the Earth's rotation. Effectively, the prime judge of 'being stationary' is the rotation sensor itself. If it registers zero rotation rate then it's stationary.
Cleonis
Hi
I am sorry for not explaining myself clearly. The sensor that I am using is ADIS16350 from Analog Devices. Before taking reading I use a command to correct the gyroscope bias. Then I am using the following equations to calculate the rotation angle (theta) from the angular rate (w).
theta(k+1) = (w(k+1) - w(0))*t + theta(k);
Here t=0.01 as the sampling rate is set to 100Hz. The w(0) is zero frequency offset of the rate gyro and is determined as the average of the angular rate for the initial 49 samples. 'k' represents the sample number.
When the sensor is held with no motion (rate gyros readings are close to zero but not zero) the drift occurs. I believ this is because the rate gyro gives a slight reading.
Is there a conventional method to deal with the drift? I am sorry if I am asking obvious questions. It is just that I am very new to dealing with sensors.
Thank you!
Chathuri
I apologize for doubting the thoroughness of your preparations. Clearly you know as much as I do. I have to confess I'm not better equipped than you are to find where the drift is entering the system. Good luck with your efforts.
Cleonis
  • · Replies 20 ·
