Linear Algebra- Transformations and
The discussion revolves around identifying which linear transformations from ℝ³ to ℝ³ are invertible and finding their inverses if they exist. The transformations in question include reflection about a plane, orthogonal projection onto a plane, scaling by a factor of 5, and rotation about an axis.
  • Participants discuss the invertibility of various transformations and attempt to articulate the nature of their inverses. There is a focus on understanding the properties of reflections, scalings, and rotations, with some participants questioning the assumptions behind their reasoning.
The conversation has progressed with some participants providing insights into the nature of the inverses for certain transformations. There is a recognition that the inverse of a reflection is itself, and that scaling and rotation have specific inverse operations. However, there remains some ambiguity regarding the general formulation of these transformations.
Participants note the lack of detail in the problem statement, which affects their ability to provide specific formulas for the transformations. There is also mention of the complexity involved in deriving a generic inverse matrix for reflections based on arbitrary planes.
KyleS4562
Question:
Which of the following linear transformations T from |R^3 to |R^3 are invertible? Find The inverse if it exists.
a. Reflection about a plane
b. Orthogonal projection onto a plane
c. Scaling by a factor of 5
d. Rotation about an axis
Well I know only a, c, and d are invertible but I do not know how to go about finding their inverses. Only i have assumed so far it involves some vector <x,y,z> about some arbitrary thing such as in part a, a plane through the origin with an arbitrary normal <a,b,c> but I am not even sure about that.
Hi KyleS4562, welcome the Forums. I think they want a fairly abstract answer to each question, since they didn't describe most of them in enough detail to let you give a formula like <x,y,z> transforms to whatever. Just answer in the same spirit they asked. What's the inverse of a reflection? What's inverse of an expansion by 5? What's the inverse of a rotation? Just answer in words.
Thanks... i have about a page and a have worth of random row reducing trying to come up with a generic inverse matrix for a with any plane with any given <a,b,c> normal and I still not got the final matrix so I like your answer better.
Absolutely, now what is your answer? I'd like to see it to make sure we're on the same wavelength.
A. Invertible. Let's call this transformation T which as a transformation matrix A. So since it is invertible there exists an A^-1 such that: T(<x,y,z>)= <x1,y1,z1> where A<x,y,z> = <x1,y1,z1> so that A^-1 <x1,y1,z1> = <x,y,z> for any given plane
and something like that for the other ones or am I being to vague?
No, you are being too specific. Isn't the inverse of a reflection the same reflection? Just say that, I know you know it.
Wow I didn't think of that. So it is just A^-1 = A
then for b we can actually do it since
A= [5,0,0] [0,5,0] [0,0,5]
A^-1 = [1/5,0,0] [0,1/5,0] [0,0,1/5]
then d if a rotation around an axis is defined by theta degrees than the inverse matrix will rotate the vector 2pi-theta in the same direction
Right, exactly. The inverse of scaling by 5 is scaling by 1/5. And the inverse of a rotation around an axis by theta is rotation around the same axis by -theta. Or as you put it 2pi-theta. But they are the same thing.
Thank you very much for all your help
  • · Replies 25 ·
  • · Replies 18 ·
