Time invariant Green's function (inpulse response)
The discussion centers on the concept of time invariance in systems, specifically regarding Green's function and impulse response. When a delta input is applied at time t=0, the system generates an impulse response function h(t). If the delta input is delayed by tau, the response becomes g(t)=h(t-tau), confirming the system's time invariance. A time-variant system, however, would produce a response h(t, t-t0), indicating a dependency on both time variables.
  • Understanding of impulse response in linear systems
  • Familiarity with delta functions in signal processing
  • Knowledge of time invariance vs. time variance in systems
  • Basic concepts of Green's functions in differential equations
  • Study the properties of Green's functions in linear systems
  • Learn about time-invariant systems in control theory
  • Explore the implications of impulse response in signal processing
  • Investigate the mathematical formulation of delta functions and their applications
Students and professionals in engineering, particularly those focused on control systems, signal processing, and applied mathematics, will benefit from this discussion.
fisico30
Hello Forum,
given a input=delta located at time t=0, the system will respond generating a function h(t).
If the delta is instead located at t=t0 (delayed by tau), the system will respond with a function g(t)=h(t-tau), just a shifted version of the response for the delta a t=0...
If this is the case, the system is time invariant and the impulse response is said to be only a function of t-t0...: h(t-t0)
If the system was time variant instead, it will be a function h(t,t-t0), that is, a function of both time t and t-t0...it is as if it was a function of two variables...
I am not clear on this: isn't the function h, the impulse response, a function of time t also in the case of time invariant system?
To be time invariant, does the variable t need to always occur with t0 in a subtraction?
thanks,
Fisico30
My understanding is that once you have proved that the system is time invariant, i.e. h(t) = h(t-t0), you can safely drop t0 in the expression and simply state the impulse response is h(t).
