Calculating Gravitational Force Between Earth & 2.6-kg Object
The discussion revolves around calculating the gravitational force between the Earth and a 2.6-kg object on its surface. The problem involves using known values such as the mass of the Earth, the mass of the object, and the distance from the surface to the center of the Earth.
  • Exploratory, Assumption checking
  • Participants discuss the formula for gravitational force and question the necessity of using the gravitational constant. There is confusion regarding the application of the formula and the meaning of gravitational acceleration.
Some participants express uncertainty about their calculations and seek clarification on the problem's requirements. There is acknowledgment of differing interpretations of the problem, and guidance is requested to better understand the approach needed.
Participants note the hint suggesting a quick solution and express frustration over their inability to arrive at the correct answer. There is a sense of confusion regarding the role of gravitational acceleration in the context of the problem.
Cloudy789
Calculate the magnitude of the gravitational force between the Earth and a 2.600-kg mass on the surface of the earth. The distance to the center of the Earth from the surface is 6370 km and the mass of the Earth is 5.98e+24 kg. HINT: This problem should take you about 5 seconds to solve. If you use G to answer this problem, you are not thinking.
M object = 2.6 kg
M Earth = 5.98 X10+24
G constant = 9.81 m/s^2
Distance between masses = 6,370,000 m
F = G[(M1*M2)/r^2)]
9.81[(2.6*5.98e+24)/(6,370,000^2)]
9.81[(1.5548e+25)/(4.05769e+13)]
9.81(3.832e+11)
3.7589e+12 N
Yet, Capa says this is wrong and I can't think of another way to do this. Especially not without the G Constant.
This should take 5 seconds to solve as the problem stated.
F = ma
What is a? When one says F = mg, where g is the gravitational acceleration, what is the force acting upon?
Wow... I am truly an idiot.
Thank you.
Ok, so I'm working on the same problem and feel like a complete moron because I don't see what you're getting at... could someone give me a bit more information so I can understand where this problem is heading... thanks.
  • · Replies 28 ·
  • · Replies 23 ·
