Does the parametric equation of a curve determine its containment in a plane?
  • Thread starter Thread starter hungryhippo
    Curve Plane
The discussion revolves around determining whether a parametric equation of a curve is contained within a plane. Participants explore the relationship between parametric equations and geometric properties in three-dimensional space.
  • Participants discuss various methods to show that a curve defined by parametric equations lies in a plane, including the use of tangent vectors, normal vectors, and specific points on the curve.
The conversation is ongoing, with participants offering different perspectives on the necessity of tangent vectors versus using parametric equations directly. Some suggest methods involving cross products and dot products to establish relationships between points and planes.
There is a focus on the need for specific examples and the implications of using different points to define normals. Participants also express uncertainty about the correctness of their approaches and calculations.
hungryhippo
Given a parametric equation of a curve, how would you show that it is contained in a plane?
In 3-D space, a plane is defined by a point, and a vector that is orthogonal to the plane. For this question type, you're only given the parametric equation.
How I would appraoch this problem, would use t=0 to find a point on the curve that exists. Then, would I just find another point, in which it doesn't exist on the curve, since two nonparallel vectors are needed. Then, I would find the normal (n) by taking the cross product of those points...Would this be the way to go? If so, would I then just conclude that since the curve contains the point with parameter t=0, it is contained in a plane?
:confused:
In desparate need of help on this
Thanks in advance
Well, yeah. Just as you say. But you need to work with tangent vectors. If you can find two nonparallel tangents then you can compute the normal. Then just show any tangent is perpendicular to that normal. If you are just working with two points on the curve then you need to find a third point to define the plane and the normal.
Hi, regarding in this question of how to prove the curve is contained in a plane. You said i need to work with tangent vectors, so i find the tangent vector for the curve, then do i just take any t (t=0, t=1) to find two nonparallel tangents to compute for the normal?
I don't see why you need to work with tangent vectors at all.
I presume you are given parametric equations for the curve, x= f(t), y= g(t), z= h(t) and an equation for the surface, F(x,y,z)= 0. Replace x, y, and z by f(t), g(t), h(t) in the equation for the surface, F(f(t), g(t), h(t))= 0. If that is true for all t, then the curve lies in the plane.
no, we were giving the parametric equations for the curve only, and need to show that the curve is contained in a plane.
so what i did was let t=0,-1,1 so obtain 3 points on the curve, and then subtracting the points, i found 3 vectors, then i cross product two of the vectors, and dot product the third vector, and i get 0, which means the vectors are coplanar, so they lie on the same plane, so the curve is contained in a plane. is that correct?
All that tells you is that those three points are contained in a plane (which is trivially true). You could do the same thing for any curve, it doesn't prove anything.
What you need to do is show that, given those three points lie on a specific plane, every other point also lies on that plane
I'm not sure exactly how you would show that every other point in the curve lies on this plane. I was thinking:
Find three points on the curve, setting t=-1,0,1. Then using those points to come up with 2 vectors v1 and v2 and taking v1 X v2. This gives us a normal vector, telling us that we have a plane (defined as a point (t=0) and a normal vector). is this sufficient enough to prove that because we have a plane in which 3 of the points of the curve lie, the rest of the points also lie in this plane?
Nooo. Let the curve r(t). If you find a normal using n=(r(1)-r(0))x(r(-1)-r(0)) now you have to show n.(r(t)-r(0))=0 (where '.' is dot product) for all t to show it's in the same plane.
does it matter if i find the normal using n=(r(1)-r(0))x(r(-1)-r(1))?
No, the normal you get by taking the cross product of any two of the differences will be parallel. This whole thing might be a little easier to get a handle on if you had a specific example of an r(t) you want to show is a plane curve. Do you?
since that doesn't matter, then I've proved n.(r(t)-r(0))=0 for all t , thanks for your help once again
My example is:
x = 1+3t+2t^2
y = 2-2t+5t^2
z = 1-t^2
phizz said:
My example is:
x = 1+3t+2t^2
y = 2-2t+5t^2
z = 1-t^2
Ok, you seem to be on the right track. That is a plane curve. Do understand why dotting the normal with r(0)-r(t) being zero proves that?
because that is the vector equation of a plane and you are showing that the normal vector N is perpendicular to r(t) which is in this plane?
Yeah, basically. Except N isn't perpendicular to r(t). It's perpendicular to r(t)-r(0). The plane might not pass through (0,0,0). That's the case for your example.
okay I am actually not getting 0 when i take the dot product...i don't know if you actually did it out but if you did is this correct? or is my math wrong?
Yes. I worked it out. You'd better show us what you are doing is you aren't getting 0 for the dot product. Remember you don't want r(t).n=0, you want (r(t)-r(0)).n=0.
