How much work is done on the skier in the first 8.9 seconds of descent?
The discussion revolves around calculating the net work done on a skier descending a slope. The skier has a mass of 79.1 kg and is sliding down at an angle of 38 degrees with a coefficient of kinetic friction of 0.09. Participants are exploring how to determine the work done over the first 8.9 seconds of descent, focusing on the forces acting on the skier, including gravity and friction.
  • Mixed
  • Participants discuss the need to calculate the net force acting on the skier, considering both gravitational and frictional forces. There are attempts to clarify the role of these forces and how they interact. Questions arise regarding the correct equations to use and the proper calculation of normal force and friction.
The discussion is ongoing, with participants providing insights into the calculations of forces and work done. Some have offered guidance on the correct approach to determining the normal force and friction, while others are still questioning their understanding of the relationships between the forces involved.
Participants are working under the constraints of a homework problem, which may limit the information available and the methods they can use. There is a focus on ensuring that calculations are accurate, particularly regarding the use of trigonometric functions in determining forces.
The Merf
ok guys, i got one that wants me to figure out how much work is done:
A skier of a mass 79.1 kg, starting from rest, slides down a slope at an angle of 38 degrees with the horizontal. The coefficient of kinetic friction, u, is 0.09. What is the net work (the net gain in kinetic energy) done on the skier in the first 8.9 s of decent?
now i don't want the answer, i just need help know what equations i need when.
I know it gives me m=79.1kg theta=38degrees coefficient of kinetic friction=.09 (not sure of unit) and t=8.9
how do i get how much work?
I have figured the mass in the vertical direction to be 48.69 (is this right?) by taking sin38=x/79.1 or 79.1sin38=x
Figure out the acceleration. What's the net force on the skier? Use Newton's 2nd law.
ok since i got 48.69 to be the mass in the y direction, i take that times -9.8 as the acceleration due to gravity and get -477.16 as the force, i think i Newtons, but where does friction come in?
I can complete this problem without friction, or even with friction, but in one dimension, but what confuses me is that usually gravity and friction work together to slow down an object, now gravity is working to speed it up and friction is trying to slow it down, so I'm not sure what equation to use
Don't think in terms of mass in a particular direction--that doesn't make much sense. Think of the component of the weight (mg) parallel to the incline, which equals mgsinθ.
Friction is another force acting on the skier; it will equal μN, where N is the normal force. (How do you determine the normal force?)
You need the net force down the incline. Since gravity and friction act in opposite directions, they will have opposite signs.
ok so N=mgcos(theta)
N=79.1x9.8xCos(38)
N=477.25 (i think it is a little different because of rounding earlier)
so friction=uN
friction=-0.09x477.25
friction=-42.95
so the net forces N+friction=477.25-42.95 or 434.30 so that is the net force
now K=mv^2
w=dK=(K-K_0)/2
so 1/2K (because he starts at rest so v_0=0 so K_0=0)
or (mv^2)/2
now m=79.1kg, v=axt or because a=F/m v=434.30/79.1x8.9 or 48.87m/s
so K=1/2(79.1)(48.87)^2
w=94,456.35j
(is this right and is joules the right unit?)
N=79.1x9.8xCos(38)
Redo this calculation. (Cosine, not sine!)
oops... my bad, i did use sin i just accidentally wrote cos
so is it supposed to be cos?
You should have used cosine, as written.
ok thanks
N=79.1x9.8xCos(38)
N=610.85
so friction=uN
friction=-0.09x610.85
friction=-54.98
so the net forces N+friction=610.85-54.98 or 422.27 so that is the net force
now K=mv^2
w=dK=(K-K_0)/2
or (mv^2)/2
now m=79.1kg, v=axt or because a=F/m v=422.27/79.1x8.9 or 47.51m/s
so K=1/2(79.1)(47.51)^2
w=89,272.26j
so joules is the right unit?
N=79.1x9.8xCos(38)
N=610.85
so friction=uN
friction=-54.98
OK.
The net force is the component of gravity down the incline (not N) minus the friction force.
