Maximizing Volume: Rectangular Box in Hemisphere | Homework Problem
  • Thread starter Thread starter bodensee9
    Maximum Value
This problem involves maximizing the volume of a rectangular box inscribed in a hemisphere of radius R. The original poster is attempting to establish the relationship between the dimensions of the box and the hemisphere's constraints.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the problem, including the relationship between the box dimensions (x, y, z) and the hemisphere's equation. There are questions about the positivity of the dimensions and the method to be used for maximization, such as Lagrange multipliers or gradient methods.
The discussion is ongoing, with participants clarifying the constraints and relationships involved in the problem. Some guidance has been provided regarding the equation of the sphere and the implications for maximizing volume. Multiple interpretations of the setup are being explored.
Participants are considering the constraints of the problem, including the positivity of dimensions and the correct formulation of the hemisphere's equation. There is a focus on ensuring the mathematical relationships are accurately defined before proceeding with maximization.
bodensee9
Hello:
This is a max/min problem. I am asked to find the rectangular box of maximum volume inscribed in a hemisphere of radius R.
So I am wondering if I have set up this correctly. If say my length is x, width is y, and height is z. So, I would have max(xyz). And then would I have [tex]R^{2}-\frac{x^{2}}{4}-\frac{y^{2}}{4} = z^{2}[/tex] I am not sure if this is the correct relationship. And then my function would be: f(x, y) = [tex]xy(r^{2}-\frac{x^{2}}{4}-\frac{y^{2}}{4})[/tex]
I think I can maximize xyz using xyz^2.
thanks!
Firstly, what method are you aiming to use in order to maximize [tex]xyz[/tex]? You need to be clear in your own mind what you are going to do with f.
Setting up the problem is usually a matter of defining your constraints. i.e.
What hemisphere is your constraint [tex]R^{2}-\frac{x^{2}}{4}-\frac{y^{2}}{4} = z^{2}[/tex] describing?
Are [tex]x,y,z[/tex] all positive or can some be negative?
Also, before you get going in these problems, do you have a feel for what the correct answer might be?
it's a hemisphere, I would think that z would be all positive because I am assuming that it's the upper hemisphere. I am going to use either Lagrange multiplier's method or the usual gradient = 0 method. I am sure the answer will be some multiple of R.
Yes the answer is likely to involve R somewhere. However, your equation for the hemisphere is slightly off: can you write down the equation for a sphere of radius R in terms of x,y and z?
Once you have that, it is a simple case of restricting z to be positive as you said.
Also, maximizing the volume, V, is equivalent to maximizing V^2 so to simplify algebra you can take x^2 y^2 z^2 rather than xyz^2 which is not necessarily the same
Hello:
Thanks, so would the equation for a sphere be:
[tex]x^{2} + y^{2} + z^{2} = R^{2}[/tex]
So then my constraint is [tex]z^{2} = R^{2}-x^{2}-y^{2}?[/tex]
And then my function would be to maximize:
[tex]x^{2}y^{2}(R^{2}-x^{2}-y^{2})?[/tex]
Thanks.
  • · Replies 16 ·
