How to Calculate Charge Density Inside a Nucleus Using Gauss's Law?
The discussion focuses on calculating charge density (ρ) inside an atomic nucleus using Gauss's Law. The electric field is defined as E = αr for r < a, where α is a constant and a is the nucleus radius. Two approaches are presented: the simple version of Gauss's Law yields ρ = (3Eε₀)/r for 0 < r ≤ a, while the differential form leads to ρ = ε₀E(1 + ln a). Participants highlight potential errors in applying the divergence and suggest using spherical coordinates instead of cylindrical ones for accuracy.
  • Understanding of Gauss's Law and its applications in electrostatics
  • Familiarity with electric field concepts and charge density
  • Knowledge of vector calculus, particularly divergence in spherical coordinates
  • Basic principles of atomic structure and nuclear physics
  • Study the application of Gauss's Law in different coordinate systems, focusing on spherical coordinates
  • Learn about the implications of charge density in nuclear physics
  • Explore vector calculus techniques, specifically divergence and its physical interpretations
  • Investigate the relationship between electric fields and charge distributions in atomic models
Students and educators in physics, particularly those focusing on electromagnetism and nuclear physics, as well as researchers interested in atomic structure and charge distribution calculations.
Anti-Meson
In a model of an atomic nucleus, the electric field is given by:
E = α r for r < a
where α is a constant and a is the radius of the nucleus.
Use the differential form of Gauss's Law to calculate the charge density ρ inside the nucleus.
2. The attempt at a solution
Using the simple version of Gauss's law :
[tex]\int_{S} \underline{E}.\underline{dS} = \int_{V} \frac{\rho}{\epsilon_{0}} dV[/tex]
Yields a result [tex]\rho = \frac{3E\epsilon_{0}}{r}[/tex] for 0<r<=a
However when using the differential form:
[tex]\nabla . \underline{E} = \frac{\rho}{\epsilon_{0}}[/tex]
[tex]\frac{1}{r} \frac{\partial (r E_{r})}{\partial r} = \frac{\rho}{\epsilon_{0}}[/tex]
and when integrating with respect to r from 0 to a,
[tex]\rho = {\epsilon_{0}} E (1 + ln a )[/tex]
Any helpful advice would be appreciated.
I think you accidently used the cylindrical version of the divergence.
Why are you integrating?
I have used the cylindrical version, though this problem only depends on r so maybe use spherical? I integrated the partial differential with respect to r.
if I assume that Er is not a function of r but a constant then,
[tex]\frac{\partial (r E_{r})}{\partial r} = E_{r}[/tex]
or if i use a radial divergence from the beginning:
[tex]\nabla . E = \frac{\partial (E)}{\partial r}[/tex]
but by using that I get:
[tex]E = \frac{\rho r}{\epsilon_0}[/tex]
i.e missing a factor of 3
12K
  • · Replies 18 ·
