Finding ymax and ymin of a ball thrown straight into the air
  • Thread starter Thread starter babygiggles85
    Air Ball
The discussion focuses on calculating the maximum and minimum values of height (y) and potential energy (PE) for a 300g ball thrown straight up, starting from 2m above the ground. The ball reaches a maximum height of 12m above its release point, resulting in a total height of 14m when considering the initial height. The conservation of energy principle is applied, where potential energy is maximized at the peak of the trajectory and kinetic energy (KE) is zero at that point. The discussion emphasizes the use of kinematic equations and the importance of understanding the direction of gravitational acceleration.
  • Understanding of kinematic equations in physics
  • Knowledge of potential energy (PE) and kinetic energy (KE) concepts
  • Familiarity with the conservation of energy principle
  • Basic grasp of gravitational acceleration (g) effects on motion
  • Study kinematic equations for vertical motion in physics
  • Learn about the conservation of mechanical energy in closed systems
  • Explore potential and kinetic energy calculations in various scenarios
  • Investigate the effects of gravitational acceleration on projectile motion
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of energy transformations in projectile motion.
babygiggles85
A 300g ball is thrown straight up into the air. It is exactly 2m above the ground when it is released. It reaches a height of 12m above the height from which is was released, and then falls straight back down.
a) assume that y=0 is located at the point of release of the ball. Find the maximum and minimum values of y and PE(g). What is the total energy of the system? Find the maximum and minimum values of KE.
b) repeat part (a) with y=0 located on the ground
I'm having trouble finding what equations to use. I tried using mgh + 1/2m(vf^2-vi^2) but the problem doesn't give velocity
Here's the thing about velocity, when the ball reaches its maximum altitude, its velocity is zero. You might need to employ kinematic equations for this one. Also mind the direction of gravity. When the ball is going up, gravity is pulling down.
Regarding the energy of the system, this is a conservation of energy problem. When the ball is at the top of its trajectory, when v equals zero, the ball has the highest amount of potential energy and no kinetic energy.
So use the fact that [tex]V_{final}=0[/tex] to solve for the highest point it reaches and always keep in mind the direction of the acceleration (g). Potential is highest at top of trajectory, KE is zero there too.
14K
