Statics - Moment using scalar analysis
The discussion focuses on calculating the moment of a force using scalar analysis, specifically the moment of force F about line BC. The correct approach involves determining the perpendicular distance from the x-axis to the line of action of the force, leading to the moment value of F = 20.2 N·m. The participant initially miscalculated using the distance from point B to force F, which resulted in a value of 20 lb, close to the correct answer but ultimately incorrect. Proper geometry and trigonometric analysis are essential for accurate results.
  • Understanding of scalar analysis in statics
  • Knowledge of moments and forces in physics
  • Familiarity with trigonometric functions, particularly sine
  • Ability to apply geometry to determine distances in force analysis
  • Study the calculation of moments in statics using the right-hand rule
  • Learn about the application of trigonometric functions in force analysis
  • Explore the concept of perpendicular distances in moment calculations
  • Review scalar analysis techniques in engineering mechanics
Students in engineering mechanics, physics learners focusing on statics, and anyone needing to understand force moment calculations in practical applications.
EtherealMonkey
I think that I need to find the moment of the force F about the line BC first.
Then, using that moment, find the "projection" of [itex]M_{BC}[/itex] onto the X axis to find the answer. [itex]M_{BC}\sin \left(45^{o}\right)[/itex]
However, I am not getting anything near the solution value.
My only attempt at solving this that came close to correct was to use the distance from point B to F. That was obviously wrong (but yielded 20 lb - which was extremely close to the 20.2 given by the author.)
(I know that is wrong...) As soon as I sat the problem down to go to the next one, I immediately realized my method was incorrect, but I have tried and tried to get a correct answer and nothing has yielded in 1.5 hrs, so I digress.
I have a test this afternoon, so I cannot waste a lot of time on one that is holding me up. Two more chapters to review...
Any hints will be great!
TIA
The moment of a force about the x-axis is [tex]F_zy + F_yz[/tex]. Since only F_z is acting, there is no F_y term, so you just have to compute the y distance (the perpendicular distance from the x-axis to the line of action of the force). You need to watch your geometry and trig to get the corect y value which yields the correct answer of F = 20.2 N.m.
  • · Replies 21 ·
