Understanding Reciprocal Lattice Vectors and Orthogonality in Primitive Lattices
  • Context: Graduate
  • Thread starter Thread starter torehan
    Lattice Reciprocal
The discussion revolves around the concepts of reciprocal lattice vectors and their orthogonality with direct primitive lattice vectors. Participants explore mathematical formulations and relationships between these vectors, including the conditions for orthogonality and methods for calculating reciprocal lattice vectors.
  • One participant presents the relationship between direct lattice vectors and reciprocal lattice vectors, questioning the orthogonality conditions.
  • Another participant states the orthogonality condition as \(\vec{a}_i \cdot \vec{g}_j = 2\pi \delta_{i,j}\) and discusses a matrix approach to calculate reciprocal vectors.
  • A participant seeks clarification on the identity matrix referenced in the context of the matrix equation.
  • There is confusion expressed regarding the inversion of a (1x3) matrix, with a participant seeking further explanation.
  • One participant suggests an alternative method to derive the reciprocal vectors without using matrices, providing specific formulas for \(\vec{g_1}, \vec{g_2}, \vec{g_3}\).
  • Another participant emphasizes that both matrix and non-matrix methods can be valid, but prefers the matrix approach for its simplicity.
  • Further clarification is requested regarding the components of the vectors \(\vec{a}_i\) and \(\vec{g}_i\).
Participants express differing views on the methods for calculating reciprocal lattice vectors, with some favoring matrix approaches while others prefer direct formulas. The discussion remains unresolved regarding the best method and the specifics of vector components.
There are limitations in the discussion regarding the assumptions made about the dimensions of matrices and the definitions of the vectors involved, which may affect the clarity of the methods proposed.
torehan
[tex]f(\vec{r}) = f(\vec{r}+\vec{T})[/tex]
[tex]\vec{T}= u_{1} \vec{a_{1}} + u_{2} \vec{a_{2}}+u_{3} \vec{a_{3}}[/tex]
[tex]u_{1},u_{2},u_{3}[/tex] are integers.
[tex]f(\vec{r}+\vec{T})= \sum n_{g} e^{(i\vec{G}.(\vec{r}+\vec{R}) )}= f(\vec{r})[/tex]
[tex]e^{i\vec{G}.\vec{R} }= 1[/tex]
[tex]\vec{G}.\vec{R} = 2\pi m[/tex]
we call [tex]\vec{G}=h\vec{g_{1}} + k \vec{g_{2}}+l \vec{g_{3}}[/tex] reciprocal lattice vector.
but what about the primitive lattice vectors [tex]\vec{g_{1}} , \vec{g_{2}} , \vec{g_{3}}[/tex] ?
To simplify the discussion consider [tex]\vec{T_{1}}[/tex] in 1D;
[tex]\vec{T_{1}} = u_{1} \vec{a_{1}}[/tex]
[tex]\vec{G}.\vec{T} =(h\vec{g_{1}} + k \vec{g_{2}}+l \vec{g_{3}}) . ( u_{1} \vec{a_{1}}) = 2 \pi m[/tex]
Is there any definition that indicates direct primitive lattice vectors and reciprocal primitive lattice vectors orthogonalities?
i.e
[tex]\vec{g_{1}} . \vec{a_{1}} = 2 \pi[/tex]
[tex]\vec{g_{2}} . \vec{a_{1}} = \vec{g_{3}} . \vec{a_{1}} = 0[/tex]
g1,g2,g3 are the primitive vectors for the reciprocal lattice.
And the orthogonality condition is [tex]\vec{a}_i \cdot \vec{g}_j = 2\pi \delta_{i,j}[/tex]
A trick for calculating the reciprocal vectors is to form the matrix A where the columns are the direct lattice vectors, and the matrix G where the columns are the reciprocal lattice vectors. Then you have
[tex]G^T \cdot A = 2\pi I[/tex]
so
[tex]G = 2\pi (A^{-1})^T[/tex]
I is 3x3 identity martix isn't it?
yes it is
It's still confusing for me..
so how can I invers a (1x3) matrix?
You can get the vectors [tex]\vec{g_1}, \vec{g_2}, \vec{g_3}[/tex] without using any matrices. To do this use the following formulas:
[tex]\vec{g_1}=2\pi\frac{[\vec{a_2},\vec{a_3}]}{\vec{a_1}[\vec{a_2},\vec{a_3}]},[/tex] [tex]\vec{g_2}=2\pi\frac{[\vec{a_3},\vec{a_1}]}{\vec{a_1}[\vec{a_2},\vec{a_3}]},[/tex] [tex]\vec{g_3}=2\pi\frac{[\vec{a_1},\vec{a_2}]}{\vec{a_1}[\vec{a_2},\vec{a_3}]}.[/tex]
A and G are 3x3 matrices, not 1x3 matrices. The columns of A are the vectors of your lattice:
[tex]A = \left( <br /> \left( \! \! \begin{array}{c}\\ \vec{a}_1 \\ \, \end{array} \!\! \right)<br /> \left( \! \! \begin{array}{c}\\ \vec{a}_2 \\ \, \end{array} \!\! \right)<br /> \left( \! \! \begin{array}{c}\\ \vec{a}_3 \\ \, \end{array} \!\! \right) \right)[/tex]
Personally, I think this is easier than manually evaluating three separate cross products. But either way works.
Thanks but the discussion is how we get these formulas.
O.K , as you said ai and gi must be vectors which has three components. The question is what are these components?
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 32 ·
