Calculating the coefficient of friction
The problem involves a wedge sliding down a frictionless inclined plane with a block on top. The goal is to determine the minimum coefficient of static friction between the block and the wedge, given the gravitational acceleration.
  • Participants discuss drawing free body diagrams (FBD) to analyze forces acting on the wedge and block. There are attempts to apply Newton's second law in both x and y directions. Questions arise about how to express the equations in terms of available variables, particularly gravity, mass of the wedge, mass of the block, and the angle of inclination.
Some participants have provided insights into the relationships between forces acting on the block and wedge, suggesting that the frictional force must balance certain components of the gravitational force. There is an ongoing exploration of how to express the coefficient of static friction in terms of the masses and angle, with various interpretations being discussed.
Participants note the challenge of deriving equations with limited variables and question the assumptions made regarding the forces involved, particularly in relation to the motion of the wedge and the block.
phyz
A wedge slides down a frictionless inclined plane that makes angle with the horizontal. A small block is placed at the horizontal top side of the wedge. During the slide, the block does not move relative to the wedge. Find the minimum possible coefficient of static friction µs between the block and the wedge.
us=fsmax/Fn uk=Fk/Fn
Fn=mg
Fnet=ma
i cannot seem to figure out a way to start.
the only variable that would be given is gravity and i can't seem to derive an equation that would make me find another variable. I drew an fbd but it cannot be displayed here.
Given: g=9.8m/s
Hi phyz, welcome to PF.
If you draw the free body diagram, you can see that the force acting on the wedge and the block is
F = (M + m)*g*sinθ along the inclined plane. Here M is the mass of the wedge and m is the mass of the block.
F*cosθ pushes the block in the forward direction and F*sinθ pushes the block in the downward direction.
F*cosθ causes the frictional force between wedge and the block. To prevent the slipping of the block it should be equal to...?
The purpose of drawing a FBD is so that you can write out Newton's second law for both the x and y directions. Try doing that. Remember that the acceleration of the block must be the same as that of the wedge (and of the wedge-block system, since the wedge and block can be considered one object).
thanks guys i appreciate the help.
rl.bhat i understand the equation u got and that would mean F*cosθ and F*sinθ are both components to equal fk ? and to prevent the slipping of the block it should be equal to fsmax?
how can u solve this equation tho without varaibles other then gravity?
Obviously in terms of masses of wedge, block and the angle of inclination. Write the answer in symbols.
F=(mw+mb)*g*cosθ is the force going down the ramp. therefore for the wedge to move down the ramp and the block to not slip the F=(mw+mb)*g*cosθ must be equal to the Fsmax of the block.
so...
Fsmax = (mw+mb)*g*cosθ... since fsmax is equal to us*Fn we can sub it in...
us*Fn = (mw+mb)*g*cosθ... since Fn is equal to mb*g we can sub that in...
us*(mb*g)=(mw+mb)*g*cosθ...now we isolate for us and we get our answer...
[us*(mb*g)] / (mb*g) = [(mw+mb)*g*cosθ] / (mb*g)
Finally our answer is... us = [(mw+mb)*cosθ] / mb
i hope that's right? loll :P thanks
It should be
Fsmax = (mw+mb)*g*sinθ*cosθ... since fsmax is equal to us*Fn we can sub it in...
Since wedge is moving down ward, fn = mb*g - (mw+mb)*g*sinθ*sinθ.
  • · Replies 20 ·
  • · Replies 16 ·
