Solving Temperature Problem w/ 30g Ice & 60g Water
  • Thread starter Thread starter daisyi
    Temperature
The discussion focuses on calculating the final temperature when mixing 30 grams of ice at -20°C with 60 grams of water at 60°C. The user applied the formula Q = c*m*ΔT to determine energy transfer, calculating the energy lost by water as 2400 J and the energy gained by ice as 48015 J. The user correctly identifies that the energy lost by water equals the energy gained by ice plus the energy required for the phase change of ice to water. The equation Q(water lost) + Q(ice gained) + Q(fusion) = 0 is established to solve for the final temperature (Tf).
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with specific heat capacity (c) values for water and ice.
  • Knowledge of phase changes, particularly the heat of fusion for ice.
  • Ability to manipulate algebraic equations to isolate variables.
  • Study the specific heat capacity of water and ice for accurate calculations.
  • Learn about the heat of fusion for ice and its role in phase changes.
  • Practice solving energy balance equations in thermodynamics.
  • Explore real-world applications of heat transfer in thermal systems.
Students studying thermodynamics, educators teaching heat transfer concepts, and anyone interested in solving thermal equilibrium problems involving phase changes.
daisyi
I have a question sort of similar to the question that a different person asked earlier, but a little bit different.
okay, here it is: Find the final temperature if 30 gr. of ice at -20 deg C is mixed with 60 gr. of water at 60 deg C.
this is what I have done, but I'm not sure if I'm on the right track or where to go from here.
I have used the formula Q = c*m*change in temperature.
I calculated the amount of energy lost from the 60 grams of water to be 2400 through the above formula, and the amount of energy that the 30 grams of ice gains is 48015.
As far as what to do from there, I'm not quite sure.
the amount of energy lost by the water is the same amount of energy gained by ice plus the energy use in the phase change of ice into water. Therefore, Q(of water lost)+Q(of ice gained)+Q(of fusion)=0
=> C(of water)*M(of water)*( Tf-(Ti of water))+C(of ice)*M(ice) *(Tf-(Ti of ice))+ M(ice)*L(which is the heat of fusion)=0. I know that you have all the data except for Tf, which is the quantity you're looking for. The only problem now is that you have to deal with the numbers and the units of this eqation.
thanks, i see now where I wasn't understanding. Thanks so much! :smile:
  • · Replies 17 ·
