| Thread Closed |
Connecting to an Access 2000 .mdb database with visual C++ ADO commands |
Share Thread |
| Oct30-09, 01:15 PM | #1 |
Hello all,
I am trying to connect to an Access database, the Northwind sample database, by following this example, http://msdn.microsoft.com/en-us/library/cc811599.aspx I am using a Windows XP OS with Visual C++ 2008 Express for the compiler and IDE. The program is a console application. This example is specified for Access 2007 .accdb file types and doesn't specify if a .mdb file type will cause errors. Once I get it running correctly I will switch the path name, queries, and table names to my database. The code compiles correctly, but fails to execute. Here is the code Code:
#include <fstream>
#include <cmath>
#include <complex>
#include <iostream>
#include <iomanip>
#include <vector>
#include <limits>
#include <stdlib.h>
#include <stdio.h>
#include <time.h>
#include <fcntl.h>
#include <string.h>
#include <ctype.h>
#include <icrsint.h>
using namespace std;
#import <C:\\Program Files\\Common Files\\system\\ado\\msado15.dll> rename( "EOF", "AdoNSEOF")
_bstr_t bstrConnect = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=C:\\Program Files\\Microsoft Office\\Office\\Samples\\Northwind.mdb;";
HRESULT hr;
int main()
::CoInitialize(NULL);
const char* DAM = "ADO";
ADODB::_ConnectionPtr pConn("ADODB.Connection");
hr = pConn->Open(bstrConnect, "admin", "", ADODB::adConnectUnspecified);
if(SUCCEEDED(hr))
cout<<DAM<<": Successfully connected to database. Data source name:\n "
<<pConn->GetConnectionString()<<endl;
// Prepare SQL query
_bstr_t query = "SELECT Customers.[Company], Customers.[First Name] FROM Customers;";
cout <<DAM<<": SQL query \n "<<query<<endl;
// Execute
ADODB::_RecordsetPtr pRS("ADODB.Recordset");
hr = pRS->Open(query,
_variant_t((IDispatch *) pConn, true),
ADODB::adOpenUnspecified,
ADODB::adLockUnspecified,
ADODB::adCmdText);
if(SUCCEEDED(hr))
cout<<DAM<<": Retrieve schema info for the given result set: "<< endl;
ADODB::Fields* pFields = NULL;
hr = pRS->get_Fields(&pFields);
if(SUCCEEDED(hr) && pFields && pFields->GetCount() > 0)
for(long nIndex=0; nIndex < pFields->GetCount(); nIndex++)
cout << " | "<<_bstr_t(pFields->GetItem(nIndex)->GetName());
cout << endl;
else
cout<<DAM<<": Error: Number of fields in the result is set to zero." << endl;
cout<<DAM<<": Fetch the actual data: " << endl;
int rowCount = 0;
while (!pRS->AdoNSEOF)
cout<<" | "<<_bstr_t(pFields->GetItem(nIndex)->GetValue());
cout<< endl;
pRS->MoveNext();
rowCount++;
cout<<DAM<<": Total Row Count: " << rowCount << endl;
pRS->Close();
pConn->Close();
cout<<DAM<<": Cleanup Done" << endl;
else
cout<<DAM<<" : Unable to connect to data source: "<<bstrConnect<<endl;
::CoUninitialize();
return 0;
I don't know what is causing this. Any help would be appreciated. Thanks Matt |
| Oct31-09, 01:23 AM | #2 |
Mentor
What's the exception that is thrown? That will give you a clue as to what the problem is.
Do you know how to use the Visual Studio debugger? The value stored in hr after Open returns will give you an idea as to what's the problem. |
| Oct31-09, 08:09 AM | #3 |
The exception that is thrown is;
Unhandled exception at memory location ... The same error you would get if tried to access information outside the boundaries of an array. Yes, I know how to use the debugger. The value in the Open statement says IUknown in the location for the machine name. I have tried numerous names other than "admin" and still get the same error. Thanks Matt |
| Oct31-09, 07:15 PM | #4 |
Are you sure that:
ADODB::_ConnectionPtr pConn("ADODB.Connection"); Actually creates an ADODB::Connection object? I have just checked some of my code and it creates a connection like this: ADODB::_ConnectionPtr _DC; hr = _DC.CreateInstance( __uuidof(ADODB::Connection) ); _DC->Open( _ConnectionString.c(), L"", L"", ADODB::adAsyncConnect ); That is for connecting async to SQL server with the username and password in the connection string itself. |
| Nov2-09, 10:06 AM | #5 |
silverfrost:
Thanks. I had added your code but now I have a new error. The error is; :error C2660: 'ADODB::Connection15::Open' : function does not take 5 arguments So I am trying to pass too many arguments. Here is the code block where that occurs. Code:
hr = _DC->Open(query,
_variant_t((IDispatch *) _DC, true),
ADODB::adCmdText);
If I change the _DC->Open line to _DC->Open(query,"admin","",ADODB::adOpenUnspecified" The code compiles but, I get this error Unhandled exception at 0x7c812afb in Database Connection 2.exe: Microsoft C++ exception: _com_error at memory location 0x0012fbcc.. The debugger directs me to this snippet of code located in the msado15.tli file. Code:
inline HRESULT Connection15::Open ( _bstr_t ConnectionString, _bstr_t UserID, _bstr_t Password, long Options ) {
HRESULT _hr = raw_Open(ConnectionString, UserID, Password, Options);
if (FAILED(_hr)) _com_issue_errorex(_hr, this, __uuidof(this));
return _hr;
Thanks Matt |
| Nov2-09, 03:06 PM | #6 |
I think you are confusing the Recordset open with the Connection open. The connection open opens the connection and once it is open you can open a recordset from it. Your original code was about right, you just didn't create an object.
| Thread Closed |
Similar discussions for: Connecting to an Access 2000 .mdb database with visual C++ ADO commands
| can I access the database of an installed application? | Programming & Comp Sci | 1 | ||
| data in a databound control is not being added to an access database record | Programming & Comp Sci | 0 | ||
| Open an MS access table by Visual Basic code | Programming & Comp Sci | 6 | ||
| Achieve the benefits of normalized data even in a small Microsoft Access database | Computing & Technology | 0 | ||
| Track IT projects with this simple Access database | Computing & Technology | 0 | ||
