Solve for Angular Displacement with Acceleration: Rolling Motion Help
The discussion focuses on calculating the angular displacement of car tires during acceleration. Given a uniform acceleration of 1.12 m/s² over 0.65 seconds, the initial speed is 17 m/s, and the tire radius is 33 cm. The correct angular displacement is determined using the formula θ = ω₀t + 1/2αt², resulting in an angular displacement of approximately 41.8 degrees. The conversion from radians to degrees is also highlighted for clarity.
  • Understanding of kinematic equations for linear motion
  • Knowledge of angular motion concepts
  • Familiarity with unit conversions between meters and radians
  • Basic calculus for applying formulas involving time and acceleration
  • Study the derivation and application of kinematic equations in rotational motion
  • Learn about the relationship between linear and angular acceleration
  • Explore the concept of angular displacement in various contexts, such as wheels and gears
  • Investigate the effects of tire radius on angular displacement calculations
Students in physics, automotive engineers, and anyone interested in understanding the dynamics of rolling motion and angular displacement calculations.
wilmerena
Hi, I am working on the following problem:
As you drive down the road at 17 m/s you press on the gas pedal and speed up with a uniform acceleration of 1.12m/s2 for 0.65s. If the tires on your car have a radius of 33cm , what is their angular displacement during the period of accceleration?
This is what I did so far,
(1.12m/s^2) / 0.65s = 1.72 m/s acceleration
then 17m/s - 1.72 m/s = 15.28
15.28/.33m = 46 displacement?
Im not sure this was right?? :frown:
?? The acceleration is 1.12 m/s^2 as you stated in the problem.
You can use the formula for the distance traveled when traveling at constant acceleration.
The distance traveled is
[tex]d=17(0.65)+1/2(1.12)(0.65)^2=11.3 m[/tex]
If the wheels don`t slip then the distance traveled when the wheels make one revolution is equal to their circumference [tex]2\pi R[/tex]
Hi there,
You're definitely on the right track! To solve for angular displacement in this problem, we can use the formula:
θ = ω0t + 1/2αt^2
Where:
θ = angular displacement
ω0 = initial angular velocity (in this case, 0 since the tires start at rest)
α = angular acceleration
t = time
First, let's convert the given values to the correct units. The initial velocity and acceleration are both given in meters per second, so we'll need to convert them to radians per second and radians per second squared, respectively.
ω0 = 0 rad/s
α = 1.12 m/s^2 * (1 rad/0.33 m) = 3.39 rad/s^2
Next, we can plug these values into the formula:
θ = 0 * 0.65 + 1/2 * 3.39 * (0.65)^2 = 0.73 radians
Finally, we can convert this back to degrees if needed:
θ = 0.73 radians * (180 degrees/π radians) = 41.8 degrees
So the angular displacement of the tires during the acceleration period is approximately 41.8 degrees. I hope this helps!
