Rigid body solid: center of mass and tendency to topple
The discussion focuses on determining the conditions under which a whimsical star-shaped piece of furniture will not topple over, specifically relating to the location of its center of mass. It is established that the center of mass must remain within the area of support provided by the base. The participants suggest that the center of mass can be represented by a vector (R) and must be located within a vertical cylinder aligned with the star base's center, although it may extend beyond the base if positioned directly above one of the star's points.
  • Understanding of center of mass concepts
  • Familiarity with rigid body dynamics
  • Basic knowledge of geometric shapes and their properties
  • Ability to visualize three-dimensional objects and their stability
  • Research the mathematical formulation of center of mass for irregular shapes
  • Study the principles of stability in rigid body mechanics
  • Explore the concept of support polygons in relation to toppling
  • Learn about the effects of mass distribution on stability in furniture design
Students in physics or engineering, furniture designers, and anyone interested in the mechanics of stability and center of mass in irregularly shaped objects.
ttja
A whimsical piece of furniture has the base shaped like a star.
Formulate the condition in terms of the location of the center of mass of
the object that the piece would not topple over. A sketch would be
helpful.
Can someone help me first what the problem is asking for? I understand conceptually that the center of mass has to fall within the area support of the base, which is wherever in the area of the star base. But am i just to find the R vector to the center of mass and deem that its coordinate to fall onto the area of the plane where the base is located?
I think you would say that the center of mass must be within some cylinder centered on the vertical axis up from the center of the star base. Hmm, if it happens to be right above one of the points on the star, it can be a little further out. Maybe the volume where the c of m can be is not a cylinder but something more complicated.
  • · Replies 19 ·
  • · Replies 25 ·
