Improve Your Math Study Techniques
  • Thread starter Thread starter Noxide
    Studying
The discussion centers around improving math study techniques, with participants sharing their current methods and seeking advice on enhancing efficiency and effectiveness in their study habits. The scope includes personal experiences, strategies for balancing study focus, and reflections on academic attitudes.
  • One participant describes their current study method, which involves working through examples, doing questions, and memorizing notes, but expresses a desire for greater efficiency.
  • Another participant suggests that spending too much time memorizing may hinder the application of knowledge and recommends focusing on problem-solving to identify weaknesses.
  • There is a proposal to learn LaTeX for note-taking, particularly for upper-level math, to improve efficiency in editing notes.
  • A participant shares their struggle with setting unrealistic goals and suggests that mixing up study sections may help alleviate this issue.
  • One participant emphasizes the importance of balance and repetition in studying, advocating for a more flexible approach rather than striving for absolute mastery of one section before moving on.
  • A question is raised about overcoming feelings of arrogance after mastering a subject, prompting a response that emphasizes humility and the challenges of higher-level mathematics.
Participants express various views on effective study techniques, with some advocating for a balance between memorization and application, while others highlight the importance of humility in learning. There is no consensus on a single best approach, and multiple perspectives on study efficiency and academic attitudes remain present.
Participants mention limitations in their study methods, such as the potential inefficiency of extensive note rewriting and the challenge of setting realistic study goals. There is also acknowledgment of the varying difficulty levels in mathematics as one progresses through different topics.
This discussion may be useful for students seeking to enhance their math study techniques, those struggling with study efficiency, and individuals reflecting on their academic attitudes and approaches to learning.
Noxide
I need some tips on how to improve my study techniques.
Normally, I:
work through all the examples in a section and make my own notes
do the questions in the section and refine my notes again
write out a final copy of my notes and memorize them
Although this works well, it's just not efficient.
I need some tips to improve the efficiency of this studying system.
Mathematics news on Phys.org
Please see the posts https://www.physicsforums.com/showthread.php?t=351178".
Do you mean inefficient in that it takes up too much time? You may be spending too much time memorizing and getting everything out of the section and not spending enough time applying that knowledge by working enough problems. Working as many problems as possible is what allows you to detect your weaknesses.
Also, maybe spend less time completely rewriting your notes. Does this really improve your retention or ability to apply the material?
If you find yourself having to write up complete notes, then maybe learn LaTeX if you are planning to do pure math. It's good to learn this eventually. Plus, once you get decently proficient at it, it will allow you to quickly edit your notes rather than completely rewriting them. I would only recommend this if you are doing upper level math and not the more computation based courses.
Thanks. I read your posts and found them very helpful.
I often find that I overwhelm myself in trying to focus on 1 section and it's contents until I have completely mastered it, meanwhile neglecting most of the other sections.
How do you get out of setting unrealistic goals like trying to do every single question in a section?
I'm going to try "mixing it up" in the section before I've memorized the concepts of the section. I think I may indeed be spending too much time memorizing rather than trying.
The thing you want to achieve is balance plus repetition. It isn't reasonable to understand one section absolutely and then move on to the next. In fact, it's rare that will happen anyway. Do one section until you feel you've covered it sufficiently and then move on. Once you've finished the sections you've set out to review, then rinse and repeat. Don't set there spinning your tires on just a single idea or concept.
Will do!
heh, one more question...
How do you overcome arrogance? ie after learning a subject or a class really well, i feel as though every other class should come just as easily but without the toil. Do you have any tips on... deflating one's own academic ego?
Well for one, I just refuse the idea of arrogance, and don't entertain it at all. I also try to avoid certain mathematical lingo and fancy-talk to avoid the higher than thou attitude. Also, mathematics has a way of naturally checking one's arrogance and brings humility to even the strongest of minds. I don't know what level of courses you are taking, but as you move up the abstraction ladder of mathematics, things become much more difficult. Math students are put through the calculus, linear algebra, and differential equations sequence, but then things change direction completely and they are faced with analysis and abstract algebra. This change of pace basically says that you know nothing and now we'll build up everything from scratch. This is humbling in itself.
