Finding Limit using Derivative
  • Thread starter Thread starter Jules18
    Derivative Limit
The problem involves evaluating a limit expressed as a derivative: limθ→π/3 (Cos(θ) - 0.5)/(θ - π/3). Participants are exploring how to interpret this limit in the context of derivatives and are attempting to apply the definition of the derivative to find the limit.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants attempt to differentiate the function using the quotient rule but express confusion about the next steps. Others suggest interpreting the limit as the derivative of a function rather than directly differentiating it. There are discussions about the correct form of the limit and how to handle the 0/0 indeterminate form that arises when substituting θ = π/3.
Participants are actively engaging with the problem, with some expressing understanding of the derivative concept while others are still grappling with the limit evaluation. There is a mix of interpretations regarding the approach to take, and some guidance has been offered on applying the definition of the derivative to resolve the limit.
There is a noted confusion regarding the semantics of using θ versus x in the limit expression, which some participants feel affects their understanding of the problem. The original problem setup leads to an indeterminate form, prompting discussions about the necessity of limits in such cases.
Jules18
Express the limit as a derivative and evaluate.
limx-->pi/3 (Cos(theta) - 0.5)/(theta - pi/3)
I derived the function using quotient rule and then didn't know what to do.
(theta - pi/3)(-Sin(theta)) - (Cos(theta) - 0.5)
_______________________________________
(theta - pi/3)2
(theta - pi/3)2
You're missing the point of this exercise. You are supposed to interpret this limit as the derivative of some function, not take the derivative of it.
Recall that the derivative can be defined as this limit:
[tex]\lim_{x \rightarrow a} \frac{f(x) - f(a)}{x - a}[/tex]
Hint: cosine of what = .5?
Okay, thanks
Does the wording of the question seem kind of weird to you? because I copied it word for word
No, the wording seems fine to me.
BTW, you don't "derive" a function, you differentiate it. I know it seems weird that you don't "derive" something to get its derivative, but that's the way it is.
I got -[tex]\sqrt{3}[/tex]/2 as an answer, but I had to change the format of the derivative formula to this:
limtheta-->pi/3 [tex]\stackrel{\underline{Cos(theta + h) - Cos(theta)}}{h}[/tex]
But I don't know how to do it in the other format. Do you use conjugates, or what?
Your answer is correct, so it seems you understand what the problem is asking for. Your revised limit needs some work, though, as it needs to be in terms of h going to 0, like so:
[tex]\lim_{h \rightarrow 0} \frac{cos(\pi /3 + h) - cos(\pi /3)}{h}[/tex]
which equals -sin([itex]\pi[/itex] /3).
That's the correct answer, but I don't think that's what they're asking you to do, or at least how they want you to do the problem. Look at what Mark44 posted originally. That limit is equal to f'(a), which is f'(x) evaluated at a. Follow his hint to do it the original way. Either that or follow what he's posted above.
yeah sry Mark that's what I meant.
Anyways, I'm good on that one, but I'm still a little fuzzy on how to find this limit:
limx-->(pi/3) [tex]\stackrel{\underline{(Cos(\theta) - 0.5)}}{(\theta - \pi/3)}[/tex]
and I'm pretty sure that's what the question was asking.
This is one version of the definition of d/d(theta)[cos(theta)], evaluated at theta = pi/3. Your limit should be as theta --> pi/3. No x.
w/e about the x's and theta's that's just semantics.
I know that it's a version of d/d(theta). I want to know how to find the limit using that.
Well whether it's x or theta there changes the meaning of the problem completely. It's just a formula, but you have to sort of work backwards. An alternate definition of the derivative, which Mark44 already gave you, evaluated at the point a is
[tex]f'(a) = \lim_{\theta\to a} \frac{f(\theta)-f(a)}{\theta-a}[/tex]
You should be able to evaluate your limit from here.
Doing well in mathematics and science and engineering is partly about paying attention to details ("semantics").
Can you evaluate this limit?
You can convert the other limit to this form by letting h = [itex]\theta - \pi /3[/itex]. Theta approaching pi/3 is equivalent to h approaching 0 in the limit above.
Okay, thanks guys, sry if I sound frustrated
Except I had already made it to that step just by reading the question. It gave it to me in this format:
[tex]lim_{x->\pi /3} \stackrel{\underline{Cos(\theta ) - 0.5}}{\theta - \pi /3}[/tex]
My problem isn't converting it to this, it's how to work with this formula to find the limit.
It might seem obvious to you guys, but I'm missing some kind of technique because everytime I end up with 0/0 and I confuse myself.
Help :confused:
I think you are not realizing that cos(pi/3) = .5
I am realizing that. That's why when I plug pi/3 into theta I get
(0.5 - 0.5)/(pi/3 - pi/3)
both are zero, so I get 0/0 and I freak out
[tex]\begin{align*}\lim_{\theta\to\pi/3} \frac{\cos\theta-0.5}{\theta-\pi/3} &= \lim_{\theta\to\pi/3} \frac{\cos\theta-\cos(\pi/3)}{\theta-\pi/3} = (\cos\theta)' \,\big|_{\theta=\pi/3} \\<br /> &= -\sin\theta \,\big|_{\theta=\pi/3} = -\sin(\pi/3) \\<br /> &= -\frac{\sqrt{3}}{2}\end{align*}[/tex]
Okay I get it.
Thanks so much guys, sry
Jules18 said:
Okay I get it.
No problem. What you were missing was using the definition of derivative that was posted to evaluate the limit. You kept trying to explicitly evaluate the limit instead of applying the definition in reverse.
This is why you need limits, because you can't directly evaluate the quotient.
