How Do Phase Differences Affect the Amplitude of Combined Waves?
The discussion revolves around determining the amplitude of the resultant wave when two sinusoidal waves with the same frequency and direction are combined. The waves have amplitudes of 3.0 cm and 4.0 cm and differ in phase by π/2 radians.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the use of trigonometric identities to combine the two sinusoidal functions. There are attempts to apply the principle of superposition and to express the resultant wave in terms of a single sine or cosine function.
The discussion has progressed through various attempts to manipulate the wave equations and apply trigonometric identities. Some participants have provided guidance on how to express the combined wave, while others are questioning the application of certain identities and the implications of the phase difference.
Participants are working under the constraints of the problem statement, which specifies the amplitudes and phase difference. There is a focus on ensuring the correct application of trigonometric identities without reaching a final solution yet.
AndreAo
Determine the amplitude of the resultant wave when two sinusoidal waves having the same frequency and traveling in the same direction are combined, if their amplitudes are 3.0 cm and 4.0 cm and they differ in phase by [tex]\pi/2[/tex] rad
y(x,t)=a*sin(kx-wt)
y(x,t)=b*sin(kx-wt+[tex]\phi[/tex])
[tex]\phi[/tex] phase difference
sin a + sin b = 2sin 1/2(a+b) . cos 1/2(a-b)
Because the amplitudes are not the same couldn't solve it using the sum of sin.
Welcome to Physics Forums :smile:
I think it would be useful to use the trig identity,
sin(a+b) = _____?​
where
a = kx-wt
b = φ​
Thanks:smile:
Using the principle of superposition:
y(x,t)=a*sin(kx-wt)+b*sin(kx-wt+[tex]\varphi[/tex])
Using sin(a+b)=sin a*cos b+sin b.cos a on the second sin of the expression above leads to:
y(x,t)=a*sin(kx-wt)+b*cos(kx-wt)
But I don't see a way to group sin and cos.
AndreAo said:
Thanks:smile:
Uh, not quite. Let's look at just the sin(kx-wt + φ) term.
sin(A+B) = sinA*cosB + sinB*cosA is correct.
So what does sin(kx-wt + φ) equal? Again, use
A = kx-wt
B = φ
(I've changed a&b into A&B, since a&b were already defined as something else in the problem statement. I missed that before, sorry.)
Using just in sin(kx-wt+[tex]\phi[/tex]):
sin(kx-wt+[tex]\phi[/tex]) = sin (kx-wt)*cos [tex]\phi[/tex]+ sin([tex]\phi[/tex])*cos (kx-wt)
cos [tex]\phi[/tex] = 0
sin [tex]\phi[/tex] = 1
so sin(kx-wt+[tex]\phi[/tex]) = cos (kx-wt). What is wrong?
Oh! I missed that φ=π/2, sorry about that. :redface:
So you were right before,
Will have to think about this some more.
You want to replace the two terms by a single sine or cosine function of kx-wt, with amplitude A and phase beta.
y(x,t)=a*sin(kx-wt)+b*cos(kx-wt) = A sin (kx-wt + beta).
Apply the rule for sin (y+z) again. You will have sine and cosine of (kx-wt) on both sides of the equation. As this is an identity, it has to be true for all values of kx-wt, so the factor of the sine term on the right is "a" and that of the cosine term is "b". Then you have two equations for A and beta, solve for A.
ehild
The result before was:
a*sin(kx-wt)+b*cos(kx-wt) = A sin(kx-wt+[tex]\beta[/tex])
Applying the rule on the right side of equation:
A[sin(kx-wt)*cos [tex]\beta[/tex]+sin [tex]\beta[/tex]*cos(kx-wt)]
So, Acos [tex]\beta[/tex] = a and Asin [tex]\beta[/tex] = b
A = a/cos [tex]\beta[/tex] and A = b/sin [tex]\beta[/tex]
a/cos [tex]\beta[/tex] = b/sin [tex]\beta[/tex]
tan [tex]\beta[/tex] = b/a
tan [tex]\beta[/tex] = 0.04/0.03
tan [tex]\beta[/tex] = 1.33
[tex]\beta[/tex] = arctan 1.33
[tex]\beta[/tex] = 0.92
A = a/cos 0.92 = 0.05
The answer is y(x,t)= 0.05sin(kx-wt+0.92) which is the book answer
Redbelly and ehild, thanks for helping!
You're welcome!
