Is the Surface S a Disk Parallel to the yOz Plane?
  • Thread starter Thread starter Susanne217
    Disk Surface
The discussion revolves around a vector field and a surface defined by a parametric mapping. The original poster seeks to demonstrate that the surface is a disk parallel to the yOz plane, centered at a specific point.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • Participants explore the parametric representation of the surface and its geometric implications. There are attempts to relate the surface to a circle and questions about the necessary theorems or methods to demonstrate the parallel nature of the disk to the yOz plane.
Some participants have provided insights into the parametric equations and their implications, suggesting that the surface can be interpreted as a disk. There is ongoing exploration of how to formally show the relationship between the disk and the yOz plane, with various interpretations being discussed.
Participants note the potential extraneous information in the problem, particularly regarding the vector field, and question the relevance of certain mathematical approaches. There is also mention of constraints related to the tools available for visualizing the problem.
Susanne217
Given the vectorfield
[tex]\textbf{F}(r) = y^2\bold{i} + z^2\bold{j} + x^2\bold{k}[/tex] and the surface S defined by a mapping
[tex](\rho,\phi) \in [0,1] \times [0,2\pi] \mapsto \bold{r}(\rho,\phi) = 4\bold{i} + (1+\rho cos(\phi))\bold{j} + (2+\rho sin(\phi))\bold{k}[/tex]
show that S is a disk parallel with the plane yOz with the center at [tex]\bold{r}_c = 4\bold{i} + \bold{j} + 2\bold{k}[/tex]
I can see that I need to rewrite S is a circle and then I take y and z component of S and write them as a circle. That I get :)
But how do I use this to show that S can be viewed as plane yOz parallel with a disk?
Which theorem do I use?:cry:
No theorem. Use your brain. In parametric form your surface S is x = 4, y = 1 + r cos(t), z = 2 + r sin(t) (using r instead of rho, and t instead of theta). It's pretty easy to show that for fixed r, these equations describe a circle of radius r, centered at (4, 1, 2). If r is allowed to vary, the circles fill in a disk of radius 1.
If I then run the math I get that
[tex]\bold{F}(r(\rho,\phi)) = 4^2 + (2+r\cdot sin(t))^2 + (1+r\cdot cos(t))^2 = 18 + r^2 +2r \cdot cos(t)+2\cdot r \cdot sin(t) +18 = x^2 + y^2[/tex]
where rcos(t) = x and rsin(t) = y thus
[tex]18 + r^2 +2r \cdot cos(t)+2\cdot r \cdot sin(t) +18 = x^2 + y^2 \leftrightarrow x^2 + y^2 -18 -2x - 2y = r^2[/tex]
I don't know why you would want to come up with the equation of a sphere first. The parametric equations I gave describe exactly the disk that you want, and it is parallel to the y-z plane.
The problem seems to have extra information in it, namely the business about the vector field. This equation
defines your disk.
defines your disk.
do I need to show that the dot-product between the circle in yz plane and some line x=? is different from zero and thus they are parallel?
Every point on the disk has an x-coordinate of 4. That means that the disk is parallel to the plane x = 0 (the y-z plane).
okay to generate the circle in YoZ plane I set x = 0
and get the circle
[tex](1+rcos(t))^2 + (2+ rsin(t))^2 = r^2 + 2r \cdot cos(t) + 2r \cdot sint(t) +2[/tex] and this is then [tex]y^2 + z^2 = r^2 = -2rcos(t)- 2rsin(t) - 2[/tex]
That if I put rsin(t) = y and rcos(t) = z
that I get [tex]r^2 = (y-1)^2 + (z-1)^2 = r^2 = 1[/tex] if I insert (1,2) in that disk it gives 1. But if this is my disk how do i show that this disk i parallel with let say x=4?
No matter what r and t are, x is always 4. The disk is in the plane x= 4. A normal vector to that plane is <1, 0, 0>. That is also normal to the YZ plane.
I don't have any of the fancy math software like Mathlab, Maple etc. But I would like to know is there any website where I can do a computer drawing of this for free?
and get the circle
From an earlier post, x = 4, y = 1 + rcos(t), and z = 2 + rsin(t).
==> x = 4, y - 1 = rcos(t), and z - 2 = rsin(t)
==> x = 4 and (y - 1)2 + (z - 2)2 = r2(cos2(t) + sin2(t)) = r2
For each value of r such that 0 <= r <= 1, these parametric equations represent a circle centered at (4, 1, 2) of radius r. Each circle is in the plane x = 4, which is parallel to the y-z plane. Taken together, these circles constitute a circular disk of radius 1, centered at (4, 1, 2).
You don't need "fancy software" like Matlab or Maple to be able to do what I've done above. These software packages can be helpful at times, but if you're not able to carry out analysis like what's above, these tools might be a hindrance to your understanding.
