Thread Closed
finding fluid flow rate in a pipe, given pressure difference, length, and diameter
Share Thread
Nov8-09, 04:11 AM   #1
Oil flowing through a pipe, measured to be 135kPa 15m from the end and 88kPa discharging from the end. The diameter of the pipe is 1.5cm, the density of the oil is 876kg/m^3, and the dynamic viscosity is 0.24kg/m*s.
Find flow rate for:
a) horizontal
b) inclined 8 degrees
c) declined 8 degrees
2. Relevant equations
[tex] Re=V*D*\rho / \mu [/tex]
[tex] \Delta P = h_L * \rho *g [/tex]
[tex] h_L = f*(L/D)*(V^2)/(2*g) [/tex]
[tex] f=64/Re [/tex] (laminar flow only)
where:
Re = Reynolds Number
rho = density[tex] f=64/Re [/tex]
mu = dynamic viscosity
delta P = pressure loss
h_L = head loss
L = length
D = diameter
f = Darcy friction coefficient
3. The attempt at a solution
I solved for Re in terms of V, and for V in terms of f, and then I guessed f=0.0150 for a starting point. I got an Re of 13.8, indicating laminar flow, so I used [tex] f=64/Re [/tex] and iterated. However, my answer finally converged on f=12734.79 which doesn't look at all right. Am I doing something wrong?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Nov9-09, 11:53 PM   #2
Probably unit related. The equation for delta_p(your second equation) will have units in pascal.
Nov10-09, 09:05 AM   #3
Recognitions:
Gold Membership Gold Member
Quote by Vidatu View Post
Find flow rate for:
a) horizontal
where:
h_L = head loss
L = length
D = diameter
You need to show your work so we can give you guidance.
CS
Thread Closed
Similar Threads for: finding fluid flow rate in a pipe, given pressure difference, length, and diameter
Thread Forum Replies
Fluid Mechanic help- Find the acceleration rate of a pipe that decreases in diameter Engineering, Comp Sci, & Technology Homework 1
air flow in pipe, diameter change, affect performance? Mechanical Engineering 10
find flow given: diameter, length, pressure Mechanical Engineering 15
Diameter diff between flow pipe and component connector General Engineering 3
Flow through a pipe along a reduced diameter General Engineering 1
