| Thread Closed |
question on finding the volume of vapor and the volume of liquid |
Share Thread |
| Nov9-09, 08:47 PM | #1 |
On a hot 35 degrees celsius day you perspire 1.0 kg of water during your workout. A) what volume is occupied by the evaporated water? B) By what factor is this larger than the volume occupied by the liquid water? 2. Relevant equations PV=nRT PV=NKbT density of water is 1000 kg/m3= M/V n=Mass/ Molar mass [b]3. The attempt at a solution[/b I really have no idea on how to start this problem. I did solve for n=M/Mmol=1000g/18.02g/mol= 55.49 moles but i don't even know if I need it. Any help would be greatly appreciated. |
| Nov9-09, 09:26 PM | #2 |
I just need a hint to get going in the right direction. I'm thinking that this problem may have something to do with the phase diagram of water?
| Nov10-09, 09:23 PM | #3 |
Mentor
Welcome to PF.
What's missing here is the pressure of water. Has your class or book discussed the concept of vapor pressure ? There might be a table of water's vapor pressure in your book, for different temperatures. That information is needed to solve this. |
| Nov10-09, 09:36 PM | #4 |
Yeah we didn't talk at all about vapor pressure and the only thing that it says in my book is that we can ignore vapor pressure if we keep the tempature low. I did find that the vapor pressure of water is 2.4 kPa and 20 degrees celcius.
| Nov10-09, 09:43 PM | #5 |
I tried using the density of vapor 0.0022(since i knew the mass of 1kg) and from that find the volume of 454.5m3 but that wasn't right
| Nov10-09, 09:51 PM | #6 |
Recognitions:
You had pV=nRT and you had both n and T, so all you need is p. Imagine trapping all of the water vapor in a box that's free to expand or contract whenever it needs to. What would the pressure of the water vapor be?
| Nov10-09, 09:57 PM | #7 |
would be the same as the atmospheric pressure of 101300 Pa?
| Nov10-09, 09:58 PM | #8 |
Recognitions:
Yeah.
| Nov10-09, 10:02 PM | #9 |
so then...
P= 101300 Pa n= 1000/18.02=55.49moles T= 308 k R=8.31 Solve for V and I get 1.402 m3 |
| Nov10-09, 10:09 PM | #10 |
awesome thank you so much. I was able to figure out part b. Thank you!!! :)
| Thread Closed |
Similar discussions for: question on finding the volume of vapor and the volume of liquid
| Really quick question about finding specific volume in thermodynamics | Advanced Physics Homework | 2 | ||
| Help With Gas/Liquid Pressure/Volume | Introductory Physics Homework | 1 | ||
| Spray Volume/liquid Displacement | General Engineering | 1 | ||
| volume of a liquid in a container | Introductory Physics Homework | 5 | ||
| Liquid gas volume in Cylinder | Materials & Chemical Engineering | 1 | ||
