Uniform Circular Motion confusion.
The discussion revolves around the relationship between linear speed and angular speed in the context of uniform circular motion, specifically addressing a problem involving a cube on a rotating funnel.
  • Conceptual clarification, Problem interpretation
  • The original poster attempts to understand the equation v = 2πrω and its application in a specific problem involving a rotating funnel. Some participants question the clarity of the problem statement and the equations being used, while others suggest that the original poster clarify their understanding of the terms involved.
Participants are exploring the definitions and relationships between linear and angular speeds. Some guidance has been offered regarding the notation and potential confusion arising from mixing formats. The discussion is ongoing, with multiple interpretations of the problem being considered.
The problem involves specific parameters such as the mass of the cube, the angle of the funnel, and the coefficient of static friction, which are currently under discussion but not fully resolved.
DavidAlan
How can v = 2[tex]\pi[/tex]r[tex]\omega[/tex]?
I've looked at this a hundred different ways... I've found that v = 2[tex]\pi[/tex]r2[tex]\omega[/tex] only.
You'll have to give us at least a hint of what you are talking about. :-p
Please explain the problem you are trying to solve and what your equations are describing.
For uniform circular motion of radius r, the tangential speed v (measured in m/s) is related to the angular speed ω (measured in rad/s) by the formula: v = ωr.
The issue arose in the following problem;
A very small cube of mass m is placed on the inside of a funnel rotating around a vertical axis at a constant rate of v revolutions per second. The wall of the funnel makes an angle [tex]\theta[/tex] with the horizontal. The coefficient of static friction between cube and funnel is [tex]\mu[/tex]s and the center of the cube is at a distance r from the axis of rotation. Find (a) largest and (b) smallest values of v for which the cube will not move with respect to the funnel.
I consulted my handy dandy solutions manual and it wanted to work with the assumption that speed in this case = 2 [tex]\pi[/tex] r [tex]\omega[/tex].
I'm still scratching my head.
The purposes of defining the speed in this way is to get that F = 4 [tex]\pi[/tex]2 m r [tex]\omega[/tex]2.
Sorry for the ambiguity, I thought that someone would recognize the issue right away.
BTW, I don't know what's up with the editing but pi and omega are not powers. They just look that way... :blushing:
Makes no sense to me. What textbook is this?
That's because you're mixing Latex and regular text. Try doing it all with Latex, like this: [tex]2 \pi r \omega[/tex]. Even better is to use 'inline' latex, using the 'itex' tag: [itex]2 \pi r \omega[/itex].
It's from Resnick Haliday and Krane 4th edition volume 1.
