Mass of a sphere of varying density
The total mass of a sphere with a varying density defined by the equation \(\rho(r) = \rho_0 \left( 1 - \frac{\alpha r}{R_0} \right)\) was calculated using the constants \(\rho_0 = 5320 \, \frac{\mathrm{kg}}{\mathrm{m}^3}\), \(\alpha = 0.13\), and \(R_0 = 89.13 \cdot 10^6 \, \mathrm{m}\). The mass was determined through two integral forms, yielding a consistent result of \(1.42 \cdot 10^{28} \, \mathrm{kg}\). Despite verification with a Computer Algebra System (CAS), the solution did not match the expected answer in the online homework system, prompting a suggestion to consult the professor for clarification.
  • Understanding of integral calculus, specifically triple integrals
  • Familiarity with spherical coordinates
  • Knowledge of density functions and their applications in physics
  • Experience with Computer Algebra Systems (CAS) for verification of mathematical solutions
  • Review the derivation of mass from density functions in spherical coordinates
  • Study the implications of varying density on mass calculations
  • Learn about common pitfalls in online homework systems and how to address discrepancies
  • Explore advanced integral techniques for solving complex volume integrals
Students in physics or engineering courses, particularly those dealing with mechanics and density calculations, as well as educators seeking to clarify concepts related to mass and density integration.
Just a nobody
Given that the density of a sphere with respect to radius is [tex]\rho(r) = \rho_0 \left( 1 - \frac{\alpha r}{R_0} \right)[/tex] (where [tex]\rho_0[/tex], [tex]\alpha[/tex], and [tex]R_0[/tex] are constants), find the total mass of the sphere. The radius of the sphere is equal to [tex]R_0[/tex].
[tex]\rho_0 = 5320 \, \frac{\mathrm{kg}}{\mathrm{m}^3}[/tex]
[tex]\alpha = 0.13[/tex]
[tex]R_0 = 89.13 \cdot 10^6 \, \mathrm{m}[/tex]
[tex]Mass = \int_V dm = \int_V \! \rho(r) \, dV[/tex]
I have attempted the mass integral and found it to be:
[tex]Mass = \int_0^{2 \pi} \! \int_0^\pi \! \int_0^{R_0} \rho(r) r^2 \sin \phi \, dr \, d\phi \, d\theta = 4 \pi \rho_0 R_0^3 \left( \frac{1}{3} - \frac{\alpha}{4} \right) = 1.42 \cdot 10^{28} \, \mathrm{kg}[/tex]
I also tried a different form of the integral and came to the same solution:
[tex]Mass = \int_0^{R_0} \! \rho(r) (4 \pi r^2) \, dr = 4 \pi \rho_0 R_0^3 \left( \frac{1}{3} - \frac{\alpha}{4} \right) = 1.42 \cdot 10^{28} \, \mathrm{kg}[/tex]
I verified my integrals with a CAS to be sure they're correct. However, my solution still doesn't match the solution in my school's online homework system. This leads me to believe my logic is incorrect. Can someone lead me in the right direction on this problem?
I've checked it all, but I get the same answers as you. I'd be suspicious of your school's online homework system.
Thanks for checking my work. I'll probably talk to the professor on Monday.
  • · Replies 22 ·
  • · Replies 105 ·
13K
