Refractive Index: Methods for Determining Beyond Newton's Rings
  • Context: Undergrad
  • Thread starter Thread starter Berdi
The discussion revolves around methods for determining the refractive index of materials, specifically exploring alternatives to the Newton's Rings method. Participants consider various techniques applicable in experimental settings.
  • Exploratory, Technical explanation, Experimental/applied
  • One participant mentions using Newton's Rings to determine the refractive index of water and inquires about other methods.
  • Another participant suggests that total internal reflection (TIR) measurements, particularly critical angle measurement, provide highly sensitive refractive index determinations.
  • A different viewpoint introduces Brewster's Angle as a method that allows for measuring the refractive index of opaque objects.
  • Another participant proposes using an interferometer to compare the path lengths of coherent waves in different media, noting that this method is conceptually similar to Newton's Rings.
Participants present multiple methods for determining refractive index, indicating a lack of consensus on a single best approach. Various techniques are discussed without resolution on their relative effectiveness.
Some methods mentioned may depend on specific conditions, such as the homogeneity of particles for Mie scattering or the coherence of light in interferometry. The accuracy of different methods is also noted to vary.
This discussion may be of interest to students and researchers in experimental physics, optics, and materials science looking for alternative methods to measure refractive index.
Berdi
So, I was in my Undergraduate Labs yesterday, using Newton's Rings to determine the Refractive index of water. I was just wondering, other than measuring the angles of incident and refracted beams, if there were many other methods to determine refractive index?
Science news on Phys.org
The most sensitive measurements, AFAIK, use total internal reflection (critical angle measurement).
For small homogeneous particles, the refractive index can be measured via scattering (Mie scattering), but the accuracy is not as good as TIR.
You might also look up "Brewster's Angle". This even let's you measure the index of refraction of opaque objects.
You can use an interferometer to compare the distance a coherent wave goes in air (or ieally vacuum) with one going through an other medium and see how they add up - this is essentially what Newton's rings is doing.
20K
