Area inside r = 2 cos(θ) but outside r = 1
  • Thread starter Thread starter filter54321
    Area Outside
The problem involves finding the area inside the polar curve defined by r = 2 cos(θ) and outside the circle defined by r = 1, using double integrals. The subject area is polar coordinates and integration techniques.
  • Participants discuss the setup of the double integral and the limits of integration, with some questioning the correctness of the function being integrated and the ranges used. There is mention of needing to find the intersection points of the curves to determine appropriate limits.
The discussion is ongoing, with participants providing guidance on the integral setup and limits, but there is no explicit consensus on the correct approach or solution yet. Some participants express confusion about the integration function and the ranges, indicating a need for further clarification.
Participants highlight the importance of visualizing the curves and their intersections, suggesting that the integration limits may not be straightforward and could vary based on the polar equations provided.
filter54321
Use double integrals to find the area inside the circle r = 2 cos(θ) and outside the circle r = 1.
I figured this was too easy to require an graphic. If you can't picture the circles, imagine them in rectangular from:
r = 2 cos(θ) ==> y2+(x-2)2=1
r = 1 ==> y2+x2=1
Both circles have a radius of 1 and you need to look at all 2\pi of the objects to see the full area of overlap. So this is what I tried:
[tex]\int\stackrel{2\pi}{0}\int\stackrel{0}{1}[/tex] (2cos(θ)-r) drdθ
The book says the answer is but I can't get it:
[tex]\frac{\pi}{3}[/tex]+[tex]\frac{\sqrt{3}}{2}[/tex]
The integral to find area in polar coordinates is:
[tex]\iint_A r \, dr \, d\theta[/tex]
Adjust the limits of integration to match the equations given. The actual contents of the integral ([tex]r \, dr \, d\theta[/tex]) will remain the same.
You need to find the polar coordinates of the two curves intersections and use appropriate limits. Not everything goes from 0 to [itex]2\pi[/itex] or 0 to 1.
Generally to find an area using polar coordinate double integrals you need something like this:
[tex]A = \int_{\theta_1}^{\theta_2} \int_{r_{inner}}^{r_{outer}}1\ rdrd\theta[/tex]
and you need to determine the correct limits from your formulas and picture.
Thanks, but that doesn't really get me any closer to an answer. Is the function I'm integrating correct? What are the ranges?
I can't make much sense out of your integrals. To get area with a double integral, you integrate the function 1. You need to look at the graphs. Find the [itex]\theta[/itex]'s where they intersect by setting the r values equal.
