Thread Closed
Uniform Magnetic field in a circular coil
Share Thread Thread Tools
Nov19-09, 08:08 PM   #1
A 138 turn circular coil has a diameter of 2.00 cm and resistance of 53.0 Ω. The plane of the coil is perpendicular to a uniform magnetic field of magnitude 1.00 T. The direction of the field is suddenly reversed.
a.) Find the total charge that passes through the coil.
b.) If the reversal takes 0.100 s, find the average current in the coil.
c.) Find the average emf in the coil.
I am using stuff for a solenoid is that the same as a circular coil?
l=lenght
n= # of turns per unit length
N=n*l total # of turns
A=π*r^2
Magnetic Flux=B*A (threw one turn)
B=mu_0*n*I (magnetic field inside solenoid)
Inductance=((N*(B*A))/I)=mu_0*n^2*A*l
E=IR
I don't know what to do. Any suggestions ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov19-09, 08:09 PM   #2
mu_0= 4pi*10^-7
Nov19-09, 10:03 PM   #3
The questions seem to be listed in the reverse of the sensible order. Indeed you can use the solenoid equations on the circular current loop(this is what a solenoid is). First find the average change in flux over the time period through the coil. That gives you that average EMF, then V=IR gives you the current. Since I= dq/dt you can find then find the total charge through the wire.
Thread Closed
Tags
coil, emf, magnetic field
Thread Tools
Similar Threads for: Uniform Magnetic field in a circular coil
Thread Forum Replies
Magnetic field in an AC Solenoid Coil Classical Physics 11
magnetic field coil Classical Physics 3
Magnetic feild in circular coil Introductory Physics Homework 1
A coil with turns given magnetic field, time find the emf induced in the coil Introductory Physics Homework 4
A Coil in a uniform magnetic field. Induced emf. Introductory Physics Homework 0
