DC Shunt Motors: Differences from Simple DC Motors and Relation to Generators
In summary, the conversation discusses the differences between DC shunt motors and simple DC motors, as well as any relationship between generators. The attached URL provides torque vs RPM curves for various types of DC brush motors, with the shunt wound motor having the flattest curve. The conversation also touches on why the shunt wound motor's curve differs from that of a permanent magnet motor.
gurpreet_leh
how dc shunt motors are different from the simple dc motors and is there any relation between between generators
Welcome to the PF. What is the context of your question? What are you going to use this motor for?
The attached URL has torque vs RPM curves for four different types of dc brush motors, the most common of which are the shunt wound, the series wound, and the permanent magnet. The shunt wound dc brush motor has the flattest torque curve. See
http://www.reliance.com/mtr/mtrthrmn.htm
Bob S
Bob S
I took a quick glance at the link. Why is the shunt wound DC motor speed-torque curve different than a permanent magnet motor. I find this suprizing. Both would seem to have a constant applied flux. Do you happen to know?
I saw that, and was also puzzled.
Bob S
1. What is a DC shunt motor?
A DC shunt motor is a type of direct current (DC) motor that consists of a stator (stationary part) and a rotor (rotating part). It is called a "shunt" motor because the field winding is connected in parallel (shunt) with the armature winding. This type of motor is commonly used in applications that require a constant speed, such as in industrial machinery and appliances.
2. How does a DC shunt motor work?
A DC shunt motor works by using the forces of attraction and repulsion between two magnetic fields to create motion. When an electric current is passed through the armature winding, it creates a magnetic field that interacts with the magnetic field produced by the field winding. This interaction causes the rotor to rotate, and the speed of rotation is controlled by adjusting the input voltage.
3. What are the advantages of using a DC shunt motor?
One advantage of using a DC shunt motor is its ability to maintain a constant speed regardless of the load. This makes it suitable for applications that require a consistent output, such as in conveyor belts or pumps. Additionally, DC shunt motors have a simple design and are relatively easy to control and maintain.
4. What are the limitations of a DC shunt motor?
One limitation of a DC shunt motor is its speed regulation. While it can maintain a constant speed under varying loads, it cannot adjust its speed to match changing load conditions. DC shunt motors also require regular maintenance, including brush replacements and commutator cleaning, to ensure optimal performance.
5. How do you control the speed of a DC shunt motor?
The speed of a DC shunt motor can be controlled by adjusting the input voltage. Increasing the voltage will increase the speed, while decreasing the voltage will decrease the speed. Additionally, using a variable resistor or electronic speed controller can provide more precise speed control. Some DC shunt motors also have built-in speed control mechanisms, such as a centrifugal switch or variable field resistance.
  • Electrical Engineering
