Converging and Diverging Lens Problem: Finding the Focal Lengths"
  • Thread starter Thread starter supermenscher
    Lens optics problem
The problem involves a converging lens with a focal length of 31.8 cm positioned 21.6 cm behind a diverging lens. After applying the lens equation, the image distance for the converging lens was calculated as -12.86 cm. The focal length of the diverging lens was determined to be 12.86 cm using the formula 1/f = 1/di + 1/do, where the object distance is the distance between the two lenses. It is crucial to account for the negative image distance due to the diverging nature of the second lens.
  • Understanding of lens equations and optics principles
  • Familiarity with converging and diverging lenses
  • Knowledge of image distance and object distance concepts
  • Ability to manipulate algebraic equations
  • Study the lens equation in detail: 1/f = 1/di + 1/do
  • Explore the properties of converging and diverging lenses
  • Learn about virtual objects in optics
  • Investigate the effects of lens combinations on light paths
Students and professionals in physics, particularly those studying optics, as well as educators seeking to enhance their understanding of lens behavior and calculations.
supermenscher
I am having some trouble with this one...any help would be appreciated.
A 31.8cm focal length converging lens is 21.6cm behind a diverging lens. Parallell light strikes the diverging lens. After passing through the converging lens, the light is again parallel. What is the focal length of the diverging lens.
I used the lens equation to find the distance of the image and got 12.86cm, then plugged that into the lens equation for a diverging lens and got -8.061 cm. However, that answer is incorrect. Any help would be appreciated.
There are several ways to solve this. Let's start this way: assume the focal length of the diverging lens is -x. If so, where will image from the diverging lens be formed? (Hint: where does parallel light get focused?)
Then realize that the image formed by the first lens acts as the object for the second lens.
It seems like you have correctly used the lens equation to find the distance of the image formed by the converging lens. However, when using the lens equation for the diverging lens, you need to make sure to take into account the fact that the light is now diverging after passing through the converging lens. This means that the image distance will be negative, as the light is now spreading out instead of converging.
To find the focal length of the diverging lens, you can use the formula 1/f = 1/di + 1/do, where f is the focal length, di is the image distance, and do is the object distance. In this case, the object distance is the distance between the two lenses, which is 21.6cm. Since the light is now diverging, the image distance will be negative, so you can plug in your calculated value of -12.86cm for di. Solving for f, you should get a focal length of 12.86cm for the diverging lens.
Another way to think about this problem is to consider the converging lens as a virtual object for the diverging lens. This means that the light rays leaving the converging lens will appear to be coming from a point 21.6cm in front of the diverging lens. Using this as your object distance, you can again use the lens equation to find the focal length of the diverging lens and should get the same answer of 12.86cm.
I hope this helps! Just remember to pay attention to the direction of light rays after passing through each lens, and be careful with the signs in the lens equation. Good luck!
