Derive the Period of an Oscillating Sphere
The problem involves deriving the period of a sphere oscillating on a hemispherical concave surface at small angles. Participants are exploring concepts related to rotational dynamics, conservation of mechanical energy, and the implications of small-angle approximations in the context of oscillatory motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using conservation of mechanical energy and net torque to derive the period. There are questions about the relevance of torque versus energy conservation, the role of circular motion, and the correct application of small-angle approximations. Some participants express confusion about the relationships between angular velocity, tangential velocity, and the parameters involved.
The discussion is active, with participants sharing various attempts and expressing confusion over specific calculations and assumptions. Some guidance has been offered regarding the use of small-angle approximations and the integration of equations, but there is no explicit consensus on the correct approach or resolution of the problem.
Participants are grappling with the implications of different choices for the zero of potential energy and the effects of small-angle approximations on their equations. There is also mention of potential misinterpretations of kinetic and potential energy relationships in the context of the problem.
SpringPhysics
Derive the period of a sphere oscillating in a hemispherical concave surface at small angles.
Net Torque = I x alpha
Delta E_m = 0
The thing is, tried using the conservation of mechanical energy to get an expression and isolate for omega (7/10 M r^2 omega^2 = 0). Then I differentiated in order to get omega and alpha, and substituted alpha from the net torque equation (in this case, gravity = - Mg (R - r) sin theta) with the moment of inertia of the sphere. But then it gets really messy and I can't solve for omega without a theta. The bottom line is I don't think I quite understand whether circular motion plays a role here, and whether for the kinetic energy, the velocity in translational kinetic energy is (R-r) x omega (due to circular motion) or just r x omega, and whether the omega in rotational kinetic energy is v/(R-r) or just v/r.
Thanks
Hi SpringPhysics! :smile:
(have an alpha: α and an omega: ω and a theta: θ and try using the X2 tag just above the Reply box :wink:)
Yes, conservation of mechanical energy should give you θ'2 + f(θ) = constant …
the question says "at small angles", so now replace cos or sin by polynomials, and integrate. :wink:
(btw, it isn't (R-r)sinθ, it's (R-r)(1-cosθ))
Oh, thanks.
So torque is completely irrelevant in this question? I attempted to solve using the conservation law, but I am unsure about the tangential velocity of the sphere - is it based on the radius of the bowl or just the sphere? Also, if I use the small-angle approximation, the gravity portion of the mechanical energy completely disappears. And why would we integrate? Shouldn't we differentiate in order to get an equation in terms of α and θ, in order to relate it to the SHM equation?
Thanks.
It's irrelevant if you use conservation of energy, it's very relevant if you dont! :wink:
The speed of the point of contact is zero.
No it doesn't.
Yeah, ok, differentiate. :smile:
Sorry, I'm still very confused.
Suppose that I use the conservation of energy. Then if I set the zero of potential at the base of the bowl, the change in potential energy would be
mg[r - (R-r)(1 - cos \theta].
If I use the small angle approximation, then cos \theta becomes 1 and the change in potential energy becomes just mgr. Then the kinetic energy is the sum of translational energy and rotational energy
1/2 mv2 + 1/2 I\omega2.
Then the above becomes
1/2 m(r\omega)2 + 1/2 (2/5 mr2)\omega2
Even without solving for omega, there is no R variable here!
Suppose I use torque. Then
\alpha = -mg(R-r)sin\theta / (2/5 mr2) = -5/2 g(R-r)/r2.
When I integrate this from a small angle \theta to 0, I get
-5/2 g(R-r)/a2 (cos \theta - 1).
If I use the small angle approximation, cos \theta = 1 and then the entire thing becomes zero.
What am I doing wrong?
(what happened to that θ ω and α i gave you? :confused:)
SpringPhysics said:
… If I use the small angle approximation, then cos \theta becomes 1 …
No, cosθ becomes 1 - θ2/2. :smile:
1/2 m(r\omega)2
No, v depends on R also. :wink:
Sorry, I couldn't make it work (more like, I don't know how to make it work).
According to my textbook though, cos theta = 1 :confused: It doesn't mention the second derivative approximation (is there a way to derive it?).
I'll try it out first, thanks.
Yes, cosθ = √(1 - sin2θ) ~ √(1 - θ2) ~ 1 - θ2/2.
Alternatively:
cosθ = 1 - θ2/2 + θ4/24 - … = ∑ (-1)nθ2n/(2n)!
sinθ = θ - θ3/6 + θ5/120 - … = ∑ (-1)nθ2n+1/(2n+1)!
Thanks.
So I used the conservation of mechanical energy.
PEi = mg[R-(R-r)cosθ]
PEf = mgr
KEi = 0
KEf = 1/2 mv2 + 1/2 I ω2
Then by equating the negative change in PE to the change in KE, I eventually end up with
g(R-r)(1-cosθ) = 1/2[(R-r)ω1]2 + 1/5 r2 ω22
I know that somehow I have to relate the two terms for kinetic energy, but I do not know how.
EDIT: I finally got something better
1 - cos θ= 7/10 (R-r)/g ω2
Now do I differentiate? I have to somehow get
T = 2 pi [7/5 (R-r)/g]1/2
(just got up :zzz: …)
Now put 1 - cos θ ~ θ2/2. :wink:
hmm … that gives θ' proportional to θ, which isn't SHM :redface:
ah, I think you're missing a constant, you've got ω= 0 when θ = 0, which can't be right.
Good morning :smile:
A constant? If I differentiate, I get [tex]\alpha[/tex] = 5g/7(R-r) sin [tex]\theta[/tex]. Using the small angle approximation, I get [tex]\alpha[/tex] = 5g/7(R-r) [tex]\theta[/tex], which mirrors the SHM equation right?
How can there be a constant? (Although I agree that it can't be true that when [tex]\theta[/tex] is zero, [tex]\omega[/tex] is zero as well.)
Can someone please help me?
SpringPhysics said:
… Using the small angle approximation, I get [tex]\alpha[/tex] = 5g/7(R-r) [tex]\theta[/tex], which mirrors the SHM equation right?
Good afternooooon. :wink:
No, you get α = a positive constant times θ, which is no good (it's exponential, ie positive feedback) …
you need α = a negative constant times θ for SHM (so it's negative feedback, or retarding).
I'm not sure, but I think you must have got your PE negative when you did KE + PE = constant.
(btw, it didn't occur to me before, but you can also use one of the standard trigonometric identities before approximating … 1 - cosθ = 2sin2(θ/2) :wink:)
(now I'm off to watch sean the sheep :-p)
I actually didn't start with KE + PE = constant, I started with the change in KE + change in PE = 0. So then the change in KE is just the negative of the change in PE.
EDIT:
It worked when I placed the zero of potential at the top of the concave surface (as opposed to at the bottom). But I don't know why it doesn't work if it's at the bottom.
Sorry for the double post, but I just found out that I used a relation incorrectly.
So I have that the displacement of the circumference of the ball is equal to [tex]\phi[/tex] times r, and also equal to R times [tex]\theta[/tex]. So I differentiate and get a relation between the angular velocities, and isolate for the angular velocity for the ball. I substitute that into the PE-KE equation, and then I'm stuck. What do I do next?
SpringPhysics said:
… I substitute that into the PE-KE equation, and then I'm stuck. What do I do next?
Sorry, you've lost me …
what is the PE-KE equation you got stuck with?
Hey, I have to derive the exact same equation for my lab too O_O
=D
I placed the zero of gravity at the top of the concave surface at the centre.
PEi = -mg(R-r)cos[tex]\theta[/tex]
PEf = -mg(R-r)
KEi = 0
KEf = 1/5 mv2 + 1/2 I[tex]\omega[/tex]2
So I = mr2
and [tex]\omega[/tex]2 = (R-r)/r [tex]\omega[/tex]
and v = (R-r)[tex]\omega[/tex]
When you substitute them into [tex]\Delta[/tex]PE + [tex]\Delta[/tex]KE = 0, you get g(1-cos[tex]\theta[/tex]) = 7/10 (R-r)[tex]\omega[/tex]2
When you differentiate with respect to time, you get gsin[tex]\theta[/tex] = [tex]\alpha[/tex] 7/5 (R-r)
Obviously, alpha is not a negative number, so what am I doing wrong?
I just used what was shown here:
http://www.egglescliffe.org.uk/physics/gravitation/balls/aproxg2.html
Enjoy :)
Thanks, but I would still like to know what went wrong with my solution.
You were trying to use trigonometry and torques, which overcomplicated matters and thus got you confused.
It's ok, I've had my fair share of experiences where I try to apply unneeded concepts to a problem and make things harder for myself :(
Torque o.0...
Nevertheless, I finally got the answer lol.
Thanks for your help guys :smile:
