Calculating Temperature Increase in Nuclear Fusion Reaction
The discussion focuses on calculating the temperature increase of fusion reactor walls subjected to a 30 keV plasma energy event. The user employs the formula T increase = (P * q) / (Cp * rho * V), where Cp is the specific heat (460 J/kg*K), rho is the density (7600 kg/m³), and V is the volume (29.61 m³). The initial calculation yields an extremely low temperature increase of approximately 10^-24 K per particle, which is clarified as being reasonable when considering the mass of the reactor walls. The final extrapolated temperature increase for one mole of plasma is approximately 27.962 K.
  • Understanding of plasma physics and energy units (eV to J conversion)
  • Knowledge of specific heat capacity and density calculations
  • Familiarity with thermodynamic principles related to heat transfer
  • Basic proficiency in mathematical extrapolation techniques
  • Research the properties of plasma and its behavior in nuclear fusion reactions
  • Learn about heat transfer mechanisms in solid materials under extreme conditions
  • Explore advanced thermodynamic calculations for large-scale energy systems
  • Investigate the implications of temperature changes on material integrity in fusion reactors
Physicists, nuclear engineers, and researchers involved in fusion energy development, as well as students studying plasma physics and thermodynamics.
Dalaran
Hi all,
I've been given an assignment to calculate the temperature increase of the fusion reactor walls in some theoretical event. It is a 30keV plasma energy in which the heat of the entire plamsa is instantaneously dropped on the wall. I can calculate volume of the wall and have the given density as well as specific heat.
My approach:
Cp = specific heat (J/kg*K) = 460
rho = density (kg/m3) = 7600
V = volume (m3) = 29.61
P = plasma energy (eV) = 30,000
and q is conversion of eV to J (1.602x10-19)
I end up some ridiculously low # of x10-24 degree celsius (or K) increase. I know that these are using very little mass at any given time, but with a plasma temperature of ~3X108 I expected some reasonable value. Is what I am doing correct or am I way out in left field with my thinking?
Appreciate the help.
Hi,
This is extremely late, but whatever.
30 KeV refers to energy per particle in the plasma. Your formula is correct on a per particle basis, and it gives 4.643*10^-23 K increase per particle of plasma. Extrapolating to, for example, on mole of plasma, gives 27.962 K increase. These numbers are small because youre heating a few hundred tons of wall material.
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 19 ·
