How Does Conservation of Momentum Explain Pressure Changes in a Pipe System?
The discussion centers on the application of conservation of momentum to explain pressure changes in a pipe system influenced by a pump. It was established that the rate of change of pressure, dP1/dt, caused by the pump at x=0 is balanced by an equivalent negative rate, -dP2/dt, in the system after 3 minutes. This equilibrium indicates that the pressure difference created by the pump is countered by the system, confirming the principle that total momentum in a closed system remains constant. The findings highlight the relationship between pressure changes and momentum in fluid dynamics.
  • Understanding of fluid dynamics principles
  • Knowledge of pressure measurement techniques
  • Familiarity with the concept of momentum in physics
  • Experience with pump operation and performance metrics
  • Research the mathematical formulation of conservation of momentum in fluid systems
  • Explore pressure measurement techniques in pipe flow applications
  • Learn about the dynamics of pump performance over time
  • Investigate the effects of pipe length on pressure changes in fluid systems
Engineers, physicists, and students studying fluid dynamics, particularly those interested in the relationship between pressure changes and momentum in pipe systems.
sarahh
Our problem is that we measured the rate of change of pressure of a liquid at different length of a pipe, for example, x=0, x=5cm, ... etc, caused by a pump at x=0-15cm=-15cm and got a result that at x=0, dP1/dt1 = -dP2/dt2, where dP1 is the pressure difference over a fixed interval, del t1, and dP2 is the pressure difference over a fixed interval, del t2,
i.e. -----------
del t1 |3 minutes | del t2
(just like a trapezium without the bottom part), and del t1=del t2. Pumping power is decreasing from t=0 to t=4minutes and pumping power =0 when t>4 minutes.
Is it accurate if we try to explain this observation as follows:
Due to conservation of momentum, the rate of momentum-changing force per unit area, dP1/dt, produced by the pump is balanced by an equivalent negative rate of momentum-changing force per unit area, -dP2/dt produced by the system after 3 minutes at x=0.
Thank you very much for your kind assistance.
Sarah
Yes, it is accurate to explain this observation using the concept of conservation of momentum. The rate of change of pressure, dP1/dt, represents the rate at which momentum is being added to the system by the pump. However, after 3 minutes, the system has reached a state of equilibrium where the pressure difference, dP2, is equal and opposite to the pressure difference created by the pump. This means that the rate of momentum-changing force per unit area, -dP2/dt, is balancing out the rate of momentum-changing force produced by the pump, dP1/dt. This is in line with the principle of conservation of momentum, which states that in a closed system, the total momentum remains constant. Therefore, your explanation is accurate.
  • · Replies 33 ·
